  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
    Most of my e21 parts are less than other places offer them. I'm sure they are just as rare, no? :P
    • Brian.B
      Brian.B
      Brian.
      Who the hell knows. Either way, their prices aren't a big difference.
      instagram @howdoyoudrivethat
      • Brian.B
        Brian.B
        Brian.
        Holy shit, found basically the best how to on this wheel bearing, with no special tools. EPIC.
        (removal)
        (Installation)
          the internet is a majestic place.
          • Brian.B
            Brian.B
            Brian.
            Yeah, I'm also being told that the reason my half shaft is sticking out a bit from the diff, is a snap ring, that's causing my entire problem.. I'm fucking LOST.
            • Brian.B
              Brian.B
              Brian.
              Posted Image
              Diff is on the leftside, pass side half shaft is on the right. gap is between the half shaft and the diff.
              • Brian.B
                Brian.B
                Brian.
                And the picture makes my car look rusty as fuck. It actually isn't corrosion resistant under coating ftw.
                  The missing snap ring theory makes sense but I dont believe it would be displaced a noticable amount like that.
                  Does that gap exist when the car is on the ground or only when it is lifted in the air?
                  • Brian.B
                    Brian.B
                    Brian.
                    ^ I originally thought maybe it pulls out when it's up in the air, but it stays out like that even when under full load.
                      I have no clue how severe the axleshaft angles are with how low you are. My guess is that with some weight in the rear, you hit a bump and the force on the axle took the path of least resistance and pulled the output flange out a bit. You should be able to just knock it back in with a wood block and a hammer. You wouldnt want your diff bearings getting all nastied up with salt, dirt, and raccoon guts.
                      • Brian.B
                        Brian.B
                        Brian.
                        Never even thought of that. I'll give that a shot tomorrow. Go figure, just started raining. The car started REALLY making this noise when it snowed last, Who the fuck nows. but thinking back now, if I were cruising at a set speed (cruise off) while holding the gas down to maintain speed, then let off, it'd make a noise in the rear that I Thought at the time was the rear dif mount starting to go. But thinking back now, it definitely was this. So that might work Snap. As with all the driving I do, I have to drive down some shitty roads (and here in Madison too). So I'll give that a shot when it lets up!
                        ❤ you.
                          fwiw, it would probably be easiest to knock the output flange back in with the axle parallel to ground.
                          • Brian.B
                            Brian.B
                            Brian.
                            That's true. I can make that happen no problem. :3
                            • Brian.B
                              Brian.B
                              Brian.
                              I think I might know exactly what happened to my car. an your theory actually makes sense.
                              The night it was snowing (the 7th of this month) The girl and I went to pick up her friend in the bmw (stupid fucking idea to begin with) but anyway, her friend is of bigger descent. and I remember having to come into the driveway at a decent speed (otherwise wouldn't make it up the stupid incline. And thinking back now, that could have entirely been it. So I'll give her a smack with the hammer and block soon!
                                Don't smack the GF's friend. Bad for all.
                                • Brian.B
                                  Brian.B
                                  Brian.
                                  ^haha, good one. Don't worry Trent I won't be smackin' no ones friends. Also, I lost my fuckin' hammer. No where to be found.
                                    Good excuse to buy a new one Brain.
                                      Is it in your butt? I found a lost gerbil in my butt once.
                                        Earl we don't need to hear about your gerbilling practices ;)
                                        • Brian.B
                                          Brian.B
                                          Brian.
                                          Thinking about purchasing a really nice 18oz Hammer. Drop $100+ on just a Hammer..
