  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
    And the picture makes my car look rusty as fuck. It actually isn't corrosion resistant under coating ftw.
      The missing snap ring theory makes sense but I dont believe it would be displaced a noticable amount like that.
      Does that gap exist when the car is on the ground or only when it is lifted in the air?
        ^ I originally thought maybe it pulls out when it's up in the air, but it stays out like that even when under full load.
          I have no clue how severe the axleshaft angles are with how low you are. My guess is that with some weight in the rear, you hit a bump and the force on the axle took the path of least resistance and pulled the output flange out a bit. You should be able to just knock it back in with a wood block and a hammer. You wouldnt want your diff bearings getting all nastied up with salt, dirt, and raccoon guts.
            Never even thought of that. I'll give that a shot tomorrow. Go figure, just started raining. The car started REALLY making this noise when it snowed last, Who the fuck nows. but thinking back now, if I were cruising at a set speed (cruise off) while holding the gas down to maintain speed, then let off, it'd make a noise in the rear that I Thought at the time was the rear dif mount starting to go. But thinking back now, it definitely was this. So that might work Snap. As with all the driving I do, I have to drive down some shitty roads (and here in Madison too). So I'll give that a shot when it lets up!
            ❤ you.
              fwiw, it would probably be easiest to knock the output flange back in with the axle parallel to ground.
                That's true. I can make that happen no problem. :3
                  I think I might know exactly what happened to my car. an your theory actually makes sense.
                  The night it was snowing (the 7th of this month) The girl and I went to pick up her friend in the bmw (stupid fucking idea to begin with) but anyway, her friend is of bigger descent. and I remember having to come into the driveway at a decent speed (otherwise wouldn't make it up the stupid incline. And thinking back now, that could have entirely been it. So I'll give her a smack with the hammer and block soon!
                    Don't smack the GF's friend. Bad for all.
                      ^haha, good one. Don't worry Trent I won't be smackin' no ones friends. Also, I lost my fuckin' hammer. No where to be found.
                        Good excuse to buy a new one Brain.
                          Is it in your butt? I found a lost gerbil in my butt once.
                            Earl we don't need to hear about your gerbilling practices ;)
                              Thinking about purchasing a really nice 18oz Hammer. Drop $100+ on just a Hammer..
                                I got to drive this car today. Was exciting. Too bad I couldn't really romp on it.. :( I hate having to baby my car...
                                  Try owning a vw. Constantly watching the temp gauge and turning the radio/heat off to make sure you don't hear your timing chains. Lol.
                                    I hardly ever run with my radio on, because 1 it hardly works, 2 its not loud 3, I wanna hear my car, incase it ever does start to implode.
                                    Also, I always watch my temp gauge, E28 cooling systems are fucking trash.
                                      How do you like this valence?
                                      Posted Image
                                      It looks good without bumpers too=)
                                        I might have just sold my hartge bumper today...
                                          That should have a smiley face after it=) Get one of these Hartge valences=P
                                          Or buy the one here:
                                          http://www.wibimmers.com/board/showthread.php?1442-e28-535is-US-front-spoiler-amp-front-bumper
