  4. My e36
My e36
turbo
170 Posts 15 Posters 3.1k Views 4 Watching
  • JeffJ
    JeffJ
    Jeff
    started to clean underneath so i can rubber coat it possibly tomorrow.
    68822A11-D065-4EB6-AA3A-6AF623455A37-432
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • JeffJ
      JeffJ
      Jeff
      cleaned up fuel cell in attempt to make it look a little better. (didnt work very well)  :mellow:
      FD23B8C4-6CBC-4B3D-97AF-74D90274272A-432
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • JeffJ
        JeffJ
        Jeff
        the super awesome fuel pump i got from earl today!!!!!!
        92A27D58-D939-408E-8550-0F4AF086CF9C-548
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • JeffJ
          JeffJ
          Jeff
          i gave my car my sweater dont want it to be cold anymore :(
          056D0400-6B1E-418A-A55B-454971A751D6-213
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            get that bmw buttoned up!!
              When do you expect it to be up and running?
              • JeffJ
                JeffJ
                Jeff
                well I'm hoping to have it on the road in a month or so just have to wait for the weather to get a little warmer so i can paint it. as for starting i need to order oil cooler parts still. after i do that i can put the intake on and start the car up.
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                • JeffJ
                  JeffJ
                  Jeff
                  today all i did on the car was caulk the gaps in the metal and rubber coat in the trunk well and under the trunk well.
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                  • JeffJ
                    JeffJ
                    Jeff
                    D6F25546-35A8-4A72-9ABE-8891CE565854-65620D56E61-A16E-403A-908E-79B0FF9199EA-656
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      What did you use to clean the underbody? I should really undercoat mine.
                      • StewCrewS
                        StewCrewS
                        StewCrew
                        Im pumped to see this thing run again
                        • JeffJ
                          JeffJ
                          Jeff
                          i used a wire wheel on a drill to get loose stuff off and clean rust. then i use denatured alcohol mixed with some water like 2/3 alcohol 1/3rd water in a spray bottle and wipe it with a rag.
                          i cant wait either but it might be a little longer due to i have to leave for work next week now i guess.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            JEFF. rides for everyone once le car is up and running.
                            and yes, thats mandatory
                            non-negotiable
                            • JeffJ
                              JeffJ
                              Jeff
                              JEFF. rides for everyone once le car is up and running.    and yes, thats mandatory     non-negotiable
                              Ha will do if im around still
                              Im finishing rubber coating the rear half of the car today nothing interesting going on at the moment.
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                              • JeffJ
                                JeffJ
                                Jeff
                                finished rubber coating so i can put the subframe in. i hate the rubber coat it sticks to everything and it smells very bad.
                                4D06D0E4-9E38-4E0A-879F-AB56909F0D8F-92950CFA11E-8F16-441A-8744-978E61BD868D-9297049F8CD-E195-4D65-8B43-963D87C3BECA-929D1AADAAE-BE0C-4F05-92DB-95EC73E03B94-929
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                  at least you got it done!!!!
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    yes so it should be dry enough tomorrow to put the subframe and differential in.
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      so i found some old pictures of the interior of the car when i first got it and just wanted to share. i know my thread is all over the place but it mine! i was in wow when i saw them and compared it to how it is now.headliner3.jpginterior4.jpginterior1.jpginterior2.jpginterior3.jpg
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        i got the subframe and differential in today. i need to get a wheel bearing before i put the trailing arms in.i found a bad one that i didnt even notice.CE1D6A5C-D644-426E-AFFA-C3F267F8476B-9979E0F968C-DCB7-43E0-82D8-8941AE727C29-9975641B262-A9CA-4DC1-8D16-6C1FB7487C3A-9973E4A61B9-0F2F-495C-A6A4-708860E52274-997
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          coming together nicely Jeff!
