  4. My e36
My e36
turbo
170 Posts 15 Posters 3.1k Views 4 Watching
    What did you use to clean the underbody? I should really undercoat mine.
    • StewCrewS
      StewCrewS
      StewCrew
      Jeff said:
      well I'm hoping to have it on the road in a month or so just have to wait for the weather to get a little warmer so i can paint it. as for starting i need to order oil cooler parts still. after i do that i can put the intake on and start the car up.
      Im pumped to see this thing run again
      • JeffJ
        JeffJ
        Jeff
        i used a wire wheel on a drill to get loose stuff off and clean rust. then i use denatured alcohol mixed with some water like 2/3 alcohol 1/3rd water in a spray bottle and wipe it with a rag.
        i cant wait either but it might be a little longer due to i have to leave for work next week now i guess.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          JEFF. rides for everyone once le car is up and running.
          and yes, thats mandatory
          non-negotiable
          • JeffJ
            JeffJ
            Jeff
            JEFF. rides for everyone once le car is up and running.    and yes, thats mandatory     non-negotiable
            Ha will do if im around still
            Im finishing rubber coating the rear half of the car today nothing interesting going on at the moment.
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • JeffJ
              JeffJ
              Jeff
              finished rubber coating so i can put the subframe in. i hate the rubber coat it sticks to everything and it smells very bad.
              4D06D0E4-9E38-4E0A-879F-AB56909F0D8F-92950CFA11E-8F16-441A-8744-978E61BD868D-9297049F8CD-E195-4D65-8B43-963D87C3BECA-929D1AADAAE-BE0C-4F05-92DB-95EC73E03B94-929
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                at least you got it done!!!!
                • JeffJ
                  JeffJ
                  Jeff
                  yes so it should be dry enough tomorrow to put the subframe and differential in.
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                  • JeffJ
                    JeffJ
                    Jeff
                    so i found some old pictures of the interior of the car when i first got it and just wanted to share. i know my thread is all over the place but it mine! i was in wow when i saw them and compared it to how it is now.headliner3.jpginterior4.jpginterior1.jpginterior2.jpginterior3.jpg
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                    • JeffJ
                      JeffJ
                      Jeff
                      i got the subframe and differential in today. i need to get a wheel bearing before i put the trailing arms in.i found a bad one that i didnt even notice.CE1D6A5C-D644-426E-AFFA-C3F267F8476B-9979E0F968C-DCB7-43E0-82D8-8941AE727C29-9975641B262-A9CA-4DC1-8D16-6C1FB7487C3A-9973E4A61B9-0F2F-495C-A6A4-708860E52274-997
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        coming together nicely Jeff!
                        • JeffJ
                          JeffJ
                          Jeff
                          thanks mitch!
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            That painted subframe and undercoating looks real good! I think I would have kept the diff cover silver but it looks great nonetheless
                            • JeffJ
                              JeffJ
                              Jeff
                              I was thinking rhe same thing after i put it up in there.
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                paint it white, that's the thing around here.
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  Ha no white!
                                  Moved fuse box and the abs unit. Going to start prepping for painting!
                                  BC8AE4A0-8AF1-4E7F-A9D4-89217B2BDC6C-118CBCA91A9-45B8-47CE-88B4-1B50F3A4AC58-118A28FF94B-D94B-43FF-A034-1C123C492466-118
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    I'd remove ABS. FYI.
                                      He did remove the abs
                                        He said he moved it
                                          He removed it.
