  4. My e36
My e36
turbo
170 Posts 15 Posters 3.1k Views 4 Watching
    When do you expect it to be up and running?
    • JeffJ
      JeffJ
      Jeff
      well I'm hoping to have it on the road in a month or so just have to wait for the weather to get a little warmer so i can paint it. as for starting i need to order oil cooler parts still. after i do that i can put the intake on and start the car up.
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • JeffJ
        JeffJ
        Jeff
        today all i did on the car was caulk the gaps in the metal and rubber coat in the trunk well and under the trunk well.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • JeffJ
          JeffJ
          Jeff
          D6F25546-35A8-4A72-9ABE-8891CE565854-65620D56E61-A16E-403A-908E-79B0FF9199EA-656
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            What did you use to clean the underbody? I should really undercoat mine.
            • StewCrewS
              StewCrewS
              StewCrew
              Im pumped to see this thing run again
              • JeffJ
                JeffJ
                Jeff
                i used a wire wheel on a drill to get loose stuff off and clean rust. then i use denatured alcohol mixed with some water like 2/3 alcohol 1/3rd water in a spray bottle and wipe it with a rag.
                i cant wait either but it might be a little longer due to i have to leave for work next week now i guess.
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  JEFF. rides for everyone once le car is up and running.
                  and yes, thats mandatory
                  non-negotiable
                  • JeffJ
                    JeffJ
                    Jeff
                    JEFF. rides for everyone once le car is up and running.    and yes, thats mandatory     non-negotiable
                    Ha will do if im around still
                    Im finishing rubber coating the rear half of the car today nothing interesting going on at the moment.
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                    • JeffJ
                      JeffJ
                      Jeff
                      finished rubber coating so i can put the subframe in. i hate the rubber coat it sticks to everything and it smells very bad.
                      4D06D0E4-9E38-4E0A-879F-AB56909F0D8F-92950CFA11E-8F16-441A-8744-978E61BD868D-9297049F8CD-E195-4D65-8B43-963D87C3BECA-929D1AADAAE-BE0C-4F05-92DB-95EC73E03B94-929
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        at least you got it done!!!!
                        • JeffJ
                          JeffJ
                          Jeff
                          yes so it should be dry enough tomorrow to put the subframe and differential in.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                          • JeffJ
                            JeffJ
                            Jeff
                            so i found some old pictures of the interior of the car when i first got it and just wanted to share. i know my thread is all over the place but it mine! i was in wow when i saw them and compared it to how it is now.headliner3.jpginterior4.jpginterior1.jpginterior2.jpginterior3.jpg
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                            • JeffJ
                              JeffJ
                              Jeff
                              i got the subframe and differential in today. i need to get a wheel bearing before i put the trailing arms in.i found a bad one that i didnt even notice.CE1D6A5C-D644-426E-AFFA-C3F267F8476B-9979E0F968C-DCB7-43E0-82D8-8941AE727C29-9975641B262-A9CA-4DC1-8D16-6C1FB7487C3A-9973E4A61B9-0F2F-495C-A6A4-708860E52274-997
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                coming together nicely Jeff!
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  thanks mitch!
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    That painted subframe and undercoating looks real good! I think I would have kept the diff cover silver but it looks great nonetheless
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      I was thinking rhe same thing after i put it up in there.
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        paint it white, that's the thing around here.
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          Ha no white!
                                          Moved fuse box and the abs unit. Going to start prepping for painting!
                                          BC8AE4A0-8AF1-4E7F-A9D4-89217B2BDC6C-118CBCA91A9-45B8-47CE-88B4-1B50F3A4AC58-118A28FF94B-D94B-43FF-A034-1C123C492466-118
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
