  4. 1990 e30
1990 e30
99 Posts 16 Posters 0 Views 1 Watching
    Nick_08 said:
    Yes, launch control certainly is absolutely useless...I'm going to figure the biggest drag radials that will fit and get them on by spring.
    I’ll preemptively pour one out for your driveline
    • N
      N
      Nick_08
      You sir...you're a gentleman!
      • N
        N
        Nick_08
        Alright I've entered full on sleeper mode. I added the 3.5" cutout and a full 3" exhaust with a resonator/bullet muffler and a walker sound fx 18160. Thing is so quiet, driving down the road can't hear the engine at all. In fact. this made me worried because now I can hear all these e30 noises I haven't heard in a long time. Subtle transmission sounds, rattles, its crazy. The car has polyurethane mounts everywhere. Sorry I forgot to take a picture of the rear section when I had it out.
          Good man! Cutouts are very under-utilized.
          loud is not always good.
            Love it! Gonna be fun turning heads with the flip of a switch.
              Well that is awesome.  A buddy of mine has had them on his procharged S197 mustang and it's quite possibly the greatest thing ever.  Everyone should have cutouts.
              • N
                N
                Nick_08
                I've started collecting parts to convert the rear of my car to 5 lug. Z4 hubs, calipers, and rotors with a mounting bracket from SRS. I intend to keep my e38 style 5's and put a 245/50 DR back there. Anyway, listen to the sound of this S369 and Tial 50mm...interior (exhaust) is so quiet all you hear is whining from the drivetrain.
                • N
                  N
                  Nick_08
                  I'm converting the rear to 5 lug using z4 hubs, this adds minimal width (like 2mm per side) unlike the z3 and ti swap. This will allow me to remove the 20mm spacer/adapters needed to run the e38 style 5's and add a much larger tire. Going from a 205/45-16 to a 245/45-16. Anyway, I need more traction...so it starts. An added bonus is the e46 325i brakes a quite a bit larger. I do have to say, the B90 paid for itself again...worth the investment 10 or so years later.
                  Edit* forgot to add, the e46 rotors are also vented...check it out.
                    What rear caliper adapters did you use? Looks like it all fit together perfectly!
                    • N
                      N
                      Nick_08
                      These are rebuilt e46 325i calipers. They fit with adapting brackets from SRS concepts. Completely bolt on, even the brake line.  I will post some pictures/measurements of the factory e30 and e46 caliper side by side. The piston is much larger on the e46 unit.
                      Part number:  34216758135 (left) &  34216758136 (right)
                        What pads are you using?
                        • N
                          N
                          Nick_08
                          Just the regular pagid.
                          • N
                            N
                            Nick_08
                            205 vs 245
                              A more aggressive pad will do wonders
                              • N
                                N
                                Nick_08
                                Wasn't sure if the extra $150 was worthwhile when I just drive on the streets? What have you had success with? I wan't impressed with the Hawk HPS.
                                • N
                                  N
                                  Nick_08
                                  Here is the e30 vs e46 rear caliper. 32mm vs 40mm piston
                                  Go the tires mounted, took a look at the fender difference here, the passenger side has been rolled/pulled and the drivers side has not been rolled yet.
                                    Do you care about noise/dust?
                                    • N
                                      N
                                      Nick_08
                                      Starting the 5 lug conversion on the front end using the IRP kit, e46 bearings, and e46 325i brakes. Threw on some new sway bar end links while I was at it since those were crusty. I'm still waiting for the carriers to come in the mail. I will update with some comparison of the calipers, the piston diameter is quite close from e30 to e46.
                                      e30 (260mm) vs e46 rotor (300mm)
                                      e30 Hawk HPS (which are trash) vs e46 Textar, not a huge difference. The textar is taller and wider.
                                      • N
                                        N
                                        Nick_08
                                        Finally got the carriers, so the calipers are on. Still need to get some anti-rattle clips. The e46 caliper piston is about 5mm larger than the e30. On another good note i've got the flex sensor harness run through the firewall and wired in, I will be working on mounting and plumbing that in soon. It's going to be badass not ever worrying about the fuel you put in the car. With the flex sensor the ECU will automatically adjust the VE table and ignition table for ethanol %.
                                          This might be on the few cars that would actually benefit from running one those Rocket Bunny Kits to fit enough tire under it.
