  4. 1990 e30
1990 e30
99 Posts 16 Posters 2.0k Views 1 Watching
    Love it! Gonna be fun turning heads with the flip of a switch.
      Well that is awesome.  A buddy of mine has had them on his procharged S197 mustang and it's quite possibly the greatest thing ever.  Everyone should have cutouts.
      • N
        N
        Nick_08
        I've started collecting parts to convert the rear of my car to 5 lug. Z4 hubs, calipers, and rotors with a mounting bracket from SRS. I intend to keep my e38 style 5's and put a 245/50 DR back there. Anyway, listen to the sound of this S369 and Tial 50mm...interior (exhaust) is so quiet all you hear is whining from the drivetrain.
        • N
          N
          Nick_08
          I'm converting the rear to 5 lug using z4 hubs, this adds minimal width (like 2mm per side) unlike the z3 and ti swap. This will allow me to remove the 20mm spacer/adapters needed to run the e38 style 5's and add a much larger tire. Going from a 205/45-16 to a 245/45-16. Anyway, I need more traction...so it starts. An added bonus is the e46 325i brakes a quite a bit larger. I do have to say, the B90 paid for itself again...worth the investment 10 or so years later.
          Edit* forgot to add, the e46 rotors are also vented...check it out.
            What rear caliper adapters did you use? Looks like it all fit together perfectly!
            • N
              N
              Nick_08
              These are rebuilt e46 325i calipers. They fit with adapting brackets from SRS concepts. Completely bolt on, even the brake line.  I will post some pictures/measurements of the factory e30 and e46 caliper side by side. The piston is much larger on the e46 unit.
              Part number:  34216758135 (left) &  34216758136 (right)
                What pads are you using?
                • N
                  N
                  Nick_08
                  Just the regular pagid.
                  • N
                    N
                    Nick_08
                    205 vs 245
                      A more aggressive pad will do wonders
                      • N
                        N
                        Nick_08
                        Wasn't sure if the extra $150 was worthwhile when I just drive on the streets? What have you had success with? I wan't impressed with the Hawk HPS.
                        • N
                          N
                          Nick_08
                          Here is the e30 vs e46 rear caliper. 32mm vs 40mm piston
                          Go the tires mounted, took a look at the fender difference here, the passenger side has been rolled/pulled and the drivers side has not been rolled yet.
                            Do you care about noise/dust?
                            • N
                              N
                              Nick_08
                              Starting the 5 lug conversion on the front end using the IRP kit, e46 bearings, and e46 325i brakes. Threw on some new sway bar end links while I was at it since those were crusty. I'm still waiting for the carriers to come in the mail. I will update with some comparison of the calipers, the piston diameter is quite close from e30 to e46.
                              e30 (260mm) vs e46 rotor (300mm)
                              e30 Hawk HPS (which are trash) vs e46 Textar, not a huge difference. The textar is taller and wider.
                              • N
                                N
                                Nick_08
                                Finally got the carriers, so the calipers are on. Still need to get some anti-rattle clips. The e46 caliper piston is about 5mm larger than the e30. On another good note i've got the flex sensor harness run through the firewall and wired in, I will be working on mounting and plumbing that in soon. It's going to be badass not ever worrying about the fuel you put in the car. With the flex sensor the ECU will automatically adjust the VE table and ignition table for ethanol %.
                                  This might be on the few cars that would actually benefit from running one those Rocket Bunny Kits to fit enough tire under it.
                                    while more tire is sweet, the thousands of dollars he’d spend on fiberglass/finishing/paint/new wheels/new tires, an aftermarket traction control setup that works with the terminator x would be cheaper.
                                      terminator x
                                      You realize I don't know how to stop myself...?
                                      • N
                                        N
                                        Nick_08
                                        I've considered just getting some fender flares but, I really want this car to look like a mostly factory e30 with some minor mods. So the only future option will be to go in...😈
                                        For now and the foreseeable future, the TCS is my foot. I can't wait to see how these new tires (and the axles) hold up.
                                        Minor updates to come soon as the flex sensor mount will be arriving in the mail today.
                                        • N
                                          N
                                          Nick_08
                                          Managed to get the flex sensor mounted under the car. I need to get two 6AN ptfe fittings to finish up the job (had the extra adapter fittings pictured laying around). I also decided to test my local premium 91 gasoline for ethanol content and contrary to what I've read on the internet, there is no ethanol (as advertised). The internet was saying even the premium-no ethanol still had some in it.
                                          Knowing the ethanol content is important because my current ve table is based on this fuel. The flex sensor should read this fuel as 0% and my will not add any fuel to compensate based on the flex multiplier table. Once the sensor begins reading ethanol %,  the ECU will multiply my base ve table to administer the proper ratio. Hooray for being able to use any fuel available.
                                          The struggle of dealing with someone else wiring harness.....
