  4. 1990 e30
1990 e30
99 Posts 16 Posters 2.0k Views 1 Watching
  • N
    N
    Nick_08
      That is flying 😎
        Jebus. Speedo went from 40 to 65 in like no seconds. This must have been the one rip where you actually found some grip...
        • N
          N
          Nick_08
          Added another spring to the wastegates :). I've never experienced anything like this before, pulls so hard. Enjoy!
          Just a 2nd gear roll on the throttle.
            Um, I built a car like that in Forza once ......
              Jeeeeeeeesus that “launch control” is useless hahah. Seems like a riot
              • N
                N
                Nick_08
                Yes, launch control certainly is absolutely useless...I'm going to figure the biggest drag radials that will fit and get them on by spring.
                  I’ll preemptively pour one out for your driveline
                  • N
                    N
                    Nick_08
                    You sir...you're a gentleman!
                    • N
                      N
                      Nick_08
                      Alright I've entered full on sleeper mode. I added the 3.5" cutout and a full 3" exhaust with a resonator/bullet muffler and a walker sound fx 18160. Thing is so quiet, driving down the road can't hear the engine at all. In fact. this made me worried because now I can hear all these e30 noises I haven't heard in a long time. Subtle transmission sounds, rattles, its crazy. The car has polyurethane mounts everywhere. Sorry I forgot to take a picture of the rear section when I had it out.
                        Good man! Cutouts are very under-utilized.
                        loud is not always good.
                          Love it! Gonna be fun turning heads with the flip of a switch.
                            Well that is awesome.  A buddy of mine has had them on his procharged S197 mustang and it's quite possibly the greatest thing ever.  Everyone should have cutouts.
                            • N
                              N
                              Nick_08
                              I've started collecting parts to convert the rear of my car to 5 lug. Z4 hubs, calipers, and rotors with a mounting bracket from SRS. I intend to keep my e38 style 5's and put a 245/50 DR back there. Anyway, listen to the sound of this S369 and Tial 50mm...interior (exhaust) is so quiet all you hear is whining from the drivetrain.
                              • N
                                N
                                Nick_08
                                I'm converting the rear to 5 lug using z4 hubs, this adds minimal width (like 2mm per side) unlike the z3 and ti swap. This will allow me to remove the 20mm spacer/adapters needed to run the e38 style 5's and add a much larger tire. Going from a 205/45-16 to a 245/45-16. Anyway, I need more traction...so it starts. An added bonus is the e46 325i brakes a quite a bit larger. I do have to say, the B90 paid for itself again...worth the investment 10 or so years later.
                                Edit* forgot to add, the e46 rotors are also vented...check it out.
                                  What rear caliper adapters did you use? Looks like it all fit together perfectly!
                                  • N
                                    N
                                    Nick_08
                                    These are rebuilt e46 325i calipers. They fit with adapting brackets from SRS concepts. Completely bolt on, even the brake line.  I will post some pictures/measurements of the factory e30 and e46 caliper side by side. The piston is much larger on the e46 unit.
                                    Part number:  34216758135 (left) &  34216758136 (right)
                                      What pads are you using?
                                      • N
                                        N
                                        Nick_08
                                        Just the regular pagid.
                                        • N
                                          N
                                          Nick_08
                                          205 vs 245
