Non-BMW Stuff on a BMW Forum
    gilber33 said:
    I think you are right. I found a few threads about people tapping the old one out and pounding a new stud in. However, all of them I read is that it took a lot of heating and an air hammer to get the old one out. I found a used set of manifolds for cheap. Easier and quicker than trying to get it out. And it sounds like the replacement studs are upwards of $20ea.
    i wouldn't bother punching out the old stud, or even buying the exact replacement bmw part. just drill out the hole/tap it. have a welder? drill out the hole and weld in a stud. no tapping needed.
      Word on the street is that welding to cast iron is a bad idea. I'd stick to tapping.
        I just picked up a spare set of manifolds for cheap. I'll get it ceramic coated to match the other and call it a day. My evenings are limited when it comes to garage time (a 2yo and a 5mo old) so this solution will be much faster.
          gilber33 said:
          I'm not too worried about the rattle. It already rattles a little bit. How was daily driveability with the flywheel being that light? Something you got used to pretty quick I assume?
          No problem at all to daily, I liked it better all around.  My wife also would drive it and had no problems.  It is in the van swap now if I ever get that done.
            Exhaust and driveshaft out so the transmission can come out.
            And started tackling the rust hole behind the rear wheel. This is after i trimmed it out. Going to cut some pieces out of sheet metal, tack them in, amd then coat it all with truck bed liner. Should be interesting.
              Did you mark the driveshaft halves before separating them? If not, try to find the balancing marks for reassembly
                Yeah, put some reference points on the splines and the threaded portion of the back half.
                  E46 question. Anyone ever see a washer pump of this style? I can't find it on FCP or ECS. I'll keep looking, but wondering if anyone knows anything. It's a totally different plug than what I'm finding online.
                    Looks older than an e46......... like so;
                    Image result for BMW washer pump motor
                    https://www.ebay.com/itm/Windshield-wiper-Washer-Pump-Motor-kit-Grommet-Rubber-Seal-For-BMW-3-5-Series-/361508792225
                    Fits the following:
                    BMW 318i
                    1984-1985 E30
                    BMW 325e
                    1984-1986 E30
                    BMW 325es
                    1986 E30
                    BMW 535i
                    1985-1988
                    BMW M5
                    1988 E28
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      M5 washer pump. Sweet upgrade!
                      time for some ///M badges
                        Pretty good detective skills. Close, but not quite though!
                        I did some digging this morning and after some google image searching, found that it's a universal washer pump from Autozone. 😒
                        https://www.autozone.com/electrical-and-lighting/windshield-washer-pump/taap-windshield-washer-pump/368548_44192_0
                        Luckily, the one down the street from where I work was able to get one in for this afternoon.
                        Do the badges make the car faster?
                        Back to the e30. Anyone know of a machine shop in the Milwaukee area that would lighten a flywheel? I called CS Performance in Butler and they do not do it.
                          Why not buy a lighter flywheel?
                            I still might go with the 7lb RHD flywheel. But I'd also like to see what my options are for have the stock one lightened.
                              Throwing this out there if anyone is interested. I think I'm going to be listing the e46 and get back into an older Volvo wagon. I'll obviously post a proper fs post with pictures.
                              2005 325iT. 134k miles. Base model (manual seats, rwd, does not have cold weather package). Starts, runs, and drives great. No CEL or other lights.  No rattles or clunks. Has the trunk cargo cover. I routinely get 30mpg to it on the highway and on our last family trip to Traverse City, MI we made it there on one tank of gas (~450 miles).
                              Work I've done to it:
                              • New control arms
                              • New sway bar links
                              • New front pads and rotors
                              • New windshield washer pump
                              • New heater control valve
                              • New fuel filter
                              • New tires (put on 12/3/18)
                              • New rear passenger window regulator
                              • New windshield cowl
                              • Passenger side seat airbag sensor emulator (to bypass seat sensor)
                              • Have new serpentine belt and AC belt, just not installed.
                              • New air filter
                              What it could use:
                              • Common e46 fuel gauge issues. It doesn't always read accurately right after filling it up, however, after a few starts the gauge reads as it should until you fill up again.
                              • Could use a driveshaft center support bearing in the near future. Every once in a while you get the "rumble strip" feel.
                              • I would do rear pads rotors at some point in the near future.
                              • New key fob (or replace batter in the current one). I am going to try to get to the dealer to order a new one.
                              • Tires should be balanced by an actual tire shop. After getting new tires there's a slight vibration at 60-65 in the steering wheel, but it's not bad, just a thing I noticed that others probably won't.
                              Asking $4,500obo for it based on what I can find for sale currently and what's been done to it. It's a great car, looking for something a little wider for the car seats.
                                Oh man. I really want a Black E46 wagon. No rust I assume?
                                ughhh. Sadly I cant justify it with all these other projects I have at the moment. Trade you a MOMster truck?
                                  lol.
                                  There's a small bubble on the hatch in the handle area. Nothing nearly as bad as what I've seen on most e46s. 😵
                                    Picked up the new daily! The e46 is still for sale!
                                    • i_love_carsI
                                      i_love_carsI
                                      i_love_cars
                                      just caught up on the last 6 pages of this. Damn I miss having a clean E30. I'm really not a fan of gray cars since it's such a common color on the road, but I always make exception if the car is cool and has a red interior. It's just such a good looking combo. The wheels help this car a ton too. It just looks awesome. Sans the deer smashing the corner of the fender. Stupid nature. I'm gonna put extra miles on my V10 and V8 this year to hopefully kill some more nature with my pollution.
                                      2007 Z4MR
                                      2003 E39 M5
                                      2002 E46 M3
                                      2021 X5 40i
                                        I agree. A car can have a boring exterior color if it has a really nice interior color. Same way but opposite too. It's either one or the other.
                                          Thank you for the compliments and your contributions of ridding the world of its nature.
