Non-BMW Stuff on a BMW Forum
    I have never had issue with high clamping force clutches and lightweight flywheels. Does the rattle get annoying if it's in neutral with the clutch pedal let out? Kinda, but who cares.
    I also ran unsprung discs on unsprung flywheels, never was bothered by that either.
    Nothing is more fun than a super free revving engine that is happy to take abusive rev matched downshifts.
    All that said, do what you think you will like most, I frequently find myself enjoying the raw mechanical side of things, that may not be the same for you!
      My friend's e30 that I drove out in California had a lightened flywheel and race clutch and the speed at which that engine revved was insane. I did stall it a couple times at first, but got used to it pretty quickly.
        gilber33 said:
        And then snapped one of the studs on the rear manifold. Soooo, if anyone has a rear exhaust manifold for an m20b25, let me know!!!!!
        is it one of the studs with enough clearance that you could drill/tap a new one in? as long as there is room for your drill, i think it should work.
        i believe the studs are originally just pressed into hole in the flange, so drilling to that size shouldnt take a lot of effort.
          FWIW I have a UUC aluminum flywheel on an M50 and it is fantastic.  Comparable weight is 11.5 lbs vs dual mass being around 26 lbs.  Minor gear rattle, but totally worth it.
            I think you are right. I found a few threads about people tapping the old one out and pounding a new stud in. However, all of them I read is that it took a lot of heating and an air hammer to get the old one out. I found a used set of manifolds for cheap. Easier and quicker than trying to get it out. And it sounds like the replacement studs are upwards of $20ea.
            I'm not too worried about the rattle. It already rattles a little bit. How was daily driveability with the flywheel being that light? Something you got used to pretty quick I assume?
              i wouldn't bother punching out the old stud, or even buying the exact replacement bmw part. just drill out the hole/tap it. have a welder? drill out the hole and weld in a stud. no tapping needed.
                Word on the street is that welding to cast iron is a bad idea. I'd stick to tapping.
                  I just picked up a spare set of manifolds for cheap. I'll get it ceramic coated to match the other and call it a day. My evenings are limited when it comes to garage time (a 2yo and a 5mo old) so this solution will be much faster.
                    No problem at all to daily, I liked it better all around.  My wife also would drive it and had no problems.  It is in the van swap now if I ever get that done.
                      Exhaust and driveshaft out so the transmission can come out.
                      And started tackling the rust hole behind the rear wheel. This is after i trimmed it out. Going to cut some pieces out of sheet metal, tack them in, amd then coat it all with truck bed liner. Should be interesting.
                        Did you mark the driveshaft halves before separating them? If not, try to find the balancing marks for reassembly
                          Yeah, put some reference points on the splines and the threaded portion of the back half.
                            E46 question. Anyone ever see a washer pump of this style? I can't find it on FCP or ECS. I'll keep looking, but wondering if anyone knows anything. It's a totally different plug than what I'm finding online.
                              Looks older than an e46......... like so;
                              Image result for BMW washer pump motor
                              https://www.ebay.com/itm/Windshield-wiper-Washer-Pump-Motor-kit-Grommet-Rubber-Seal-For-BMW-3-5-Series-/361508792225
                              Fits the following:
                              BMW 318i
                              1984-1985 E30
                              BMW 325e
                              1984-1986 E30
                              BMW 325es
                              1986 E30
                              BMW 535i
                              1985-1988
                              BMW M5
                              1988 E28
                              • The Full BananaT
                                The Full BananaT
                                The Full Banana
                                M5 washer pump. Sweet upgrade!
                                time for some ///M badges
                                  Pretty good detective skills. Close, but not quite though!
                                  I did some digging this morning and after some google image searching, found that it's a universal washer pump from Autozone. 😒
                                  https://www.autozone.com/electrical-and-lighting/windshield-washer-pump/taap-windshield-washer-pump/368548_44192_0
                                  Luckily, the one down the street from where I work was able to get one in for this afternoon.
                                  Do the badges make the car faster?
                                  Back to the e30. Anyone know of a machine shop in the Milwaukee area that would lighten a flywheel? I called CS Performance in Butler and they do not do it.
                                    Why not buy a lighter flywheel?
                                      I still might go with the 7lb RHD flywheel. But I'd also like to see what my options are for have the stock one lightened.
                                        Throwing this out there if anyone is interested. I think I'm going to be listing the e46 and get back into an older Volvo wagon. I'll obviously post a proper fs post with pictures.
                                        2005 325iT. 134k miles. Base model (manual seats, rwd, does not have cold weather package). Starts, runs, and drives great. No CEL or other lights.  No rattles or clunks. Has the trunk cargo cover. I routinely get 30mpg to it on the highway and on our last family trip to Traverse City, MI we made it there on one tank of gas (~450 miles).
                                        Work I've done to it:
                                        • New control arms
                                        • New sway bar links
                                        • New front pads and rotors
                                        • New windshield washer pump
                                        • New heater control valve
                                        • New fuel filter
                                        • New tires (put on 12/3/18)
                                        • New rear passenger window regulator
                                        • New windshield cowl
                                        • Passenger side seat airbag sensor emulator (to bypass seat sensor)
                                        • Have new serpentine belt and AC belt, just not installed.
                                        • New air filter
                                        What it could use:
                                        • Common e46 fuel gauge issues. It doesn't always read accurately right after filling it up, however, after a few starts the gauge reads as it should until you fill up again.
                                        • Could use a driveshaft center support bearing in the near future. Every once in a while you get the "rumble strip" feel.
                                        • I would do rear pads rotors at some point in the near future.
                                        • New key fob (or replace batter in the current one). I am going to try to get to the dealer to order a new one.
                                        • Tires should be balanced by an actual tire shop. After getting new tires there's a slight vibration at 60-65 in the steering wheel, but it's not bad, just a thing I noticed that others probably won't.
                                        Asking $4,500obo for it based on what I can find for sale currently and what's been done to it. It's a great car, looking for something a little wider for the car seats.
                                          Oh man. I really want a Black E46 wagon. No rust I assume?
                                          ughhh. Sadly I cant justify it with all these other projects I have at the moment. Trade you a MOMster truck?
