E30 M52
Get a new cam sensor oring. I forgot to replace mine. Healthy dose of rtv and way-too-small oring for the "fix"
Primary cam sprockets have been removed. Chain tensioner guides are groovy and will be replaced. Lower chain guides are broken/ disintegrating and will be replaced.
Someone has been in here before and had the sprockets off. The vanos seals were brittle so it wasnt for a vanos rebuild, the guides are plenty worn so it wasnt for that. So I would assume the head gasket has been replaced or something.
I could be sitting on a fresh BMW head gasket.
or
the engine could have overheated, they slapped on a 284k mile head with a Fail-Pro gasket and reused the head bolts.
who really knows.
I need to get my oil pan and baffle dropped off for welding so it is ready to go on in the near future.
Crazy how the guides were blasted already.
Journals in good shape?
Yeah, nothing to see there
Ball
Sacks
Intake cam is in but while torquing the bearing caps to 15 Nm two of the studs pulled out
I can only imagine the horror people feel as they torque head bolts into an aluminum block and feel it give way.
Not the end of the world at all but I will have to remove the cam and trays/lifters to helicoil them.
Minor annoyance. Not the progress I was hoping for today though
Odd that the head-side went. You'd think the stud would be bottomed out and the nut wouldn't turn it anymore.
But as you said. 100000 times better than a cam
1000x better than breaking a camshaft though. I'll take it.
But see now your doubling your chances at breaking it so that would be -1000x. We both know that will just cancel it self out now and create the crazy looking number "0"
Practice makes perfect?
Helicoils are garbage. Get some keenserts from McMaster!
says the guy who had to use them too many times on his all aluminum engine.
Good luck. If the helicoils give you trouble, keenserts (or timeserts) will be there for you. I had about 50% success rate with helicoils in the same application (aluminum head, low torque fasteners to secure the cams) before being shown the light by a friend.
