  4. Turbo m52 obd2
Turbo m52 obd2
turbo go fast s
123 Posts 16 Posters 2.8k Views 1 Watching
    Daggerty
    What kind of projectiles fire when the red button is pressed?
    It shoots a liquid combustible at the intercooler. I bought a generic washer container for my meth system and it came with a pump, nozzles, and that red button so I wired it up to spray the intercooler. Will I ever use it? Do I think it will give me any gains? Probably not is the answers
    Got everything put back together. I am probably going to get a different gauge holder because the 10 dollar amazon one is pretty flexible and will probably break when I take it out. Plus not really a fan of the staggered look.
    also ordered a new oil pressure gauge to match the boost one. Three miss matched gauges were killing me, and the oil pressure gauge in there now is mechanical and don't want to risk that exploding in my dash.
      What's the silver button next to the red one?
          Daggerty
          It's a dial for the manual boost controller.
          Got these wheels today they were super cheap and in near new condition.
          Have a little to much going on for me but they fit perfect 18x8 up front and 18x9 in the rear.
            Daggerty
            Put in the walbro 450, its running on a 10 gauge cable straight from the battery through a relay signaled by the original fuel pump circuit. IMG0844.JPG
            Got a matching oil pressure gauge that is elctronic still have to put the sensor in.
            got some fleebay center armrest cover for $15 and it was worth the gamble fittment wasn't perfect, I'm sure if I had another person I could've made it look better, but not bad for the price.
            Other goodies soon to go in
              Link to the cover? Looks pretty clean!
                Daggerty
                http://m.ebay.com/itm/Leather-Armrest-Console-Lid-Cover-for-BMW-E36-3-Series-1992-1999-Black-LHD-/152300094870?hash=item2375cb0596%3Ag%3ABNUAAOSwA3dYFuTk&_trkparms=pageci%3Abf62f303-3578-11e7-9034-74dbd1803768%7Cparentrq%3Af23e901915b0aa1306dab868ffffbce6%7Ciid%3A3
                  Daggerty
                  Mad fuel bro
                    I'm surprised to see the ASC still in place.
                      With all of that extra fuel flow it must be hard to keep that thing in a straight line.
                      That would explain the ASC
                        Daggerty
                        Basically installed all new front and rear suspension, solowerks coilovers, camber plates/ caster now, strut bar in the rear and soon to be in the front and adjustable rear control arms. IMG0953.JPG
                        New turbo old one had lots of shaft play, probably would've grenaded and was  soaked in oil.
                        Need to drop the rear some more just wanted to make sure I wouldn't rub. It looks goofy especially with the hoopty wheels. IMG0954.JPGIMG0955.JPG
                          I've got a fender roller if you need it
                            Thats a Juicy turbo, what did you replace it with?
                              Daggerty
                              So far I'm good but I'll keep that in mind.
                              Another Egay turdblow to4e 57 ar.
                              Gt35 on standby is going in soon but figured for 125 dollars I'll get the car up and running.
                                Daggerty
                                This is the in tank fuel line from the pump the only one that I left stock luckily this caused a no start at home. I'm guessing it was from the accidental 20+ psi pull, and the ethanol eating through it once it bulged. Just glad it happened when it did.
                                My new fuel pump wiring setup is 8 awg wire to st95 solenoid. The spade connections on a regular 50amp relay was melting. This is not the finished product still need to secure everything.IMG0972.JPG
                                  How long did it take you to diagnose that? Thats never the first thing someone checks for unless you pulled the fuel feed first and saw no fuel coming out
                                    Daggerty
                                    Problem was discovered and fixed roughly in a hour including part store run for some hoes included. I have the rear seats out because I was cleaning them and applying leather conditioner. I couldn't here the pump kick. So I checked battery voltage, it was 11.7 so I gave it a boost and still same thing. I checked voltage at pump connector that was good, and pump ohmed out at 0.01 plugged in and put my ear right by it and could here fuel splashing like the return side normally makes so I pulled it and found the offender.
                                    still need to figure out why my wastegate is not actuating, isolated the boost controller to rule that out but didn't get any further than that.
                                    • The Full BananaT
                                      The Full BananaT
                                      The Full Banana
                                      Hope you used submersible fuel line, not just fuel injection hose, or you'll have that problem again.
                                        Thanks for making me paranoid about this.
                                        I once had a surplus of fuel injection hose and I cant remember if I used that or the stuff that came with my Whinebro 255 when I installed it.
                                          Daggerty
                                          Thanks, I have some e85 safe line on order since the store didn't have any.
