  4. Turbo m52 obd2
Turbo m52 obd2
turbo go fast s
123 Posts 16 Posters 2.8k Views 1 Watching
    I'm surprised to see the ASC still in place.
      With all of that extra fuel flow it must be hard to keep that thing in a straight line.
      That would explain the ASC
        Basically installed all new front and rear suspension, solowerks coilovers, camber plates/ caster now, strut bar in the rear and soon to be in the front and adjustable rear control arms. IMG0953.JPG
        New turbo old one had lots of shaft play, probably would've grenaded and was  soaked in oil.
        Need to drop the rear some more just wanted to make sure I wouldn't rub. It looks goofy especially with the hoopty wheels. IMG0954.JPGIMG0955.JPG
          I've got a fender roller if you need it
            Thats a Juicy turbo, what did you replace it with?
              So far I'm good but I'll keep that in mind.
              Another Egay turdblow to4e 57 ar.
              Gt35 on standby is going in soon but figured for 125 dollars I'll get the car up and running.
                This is the in tank fuel line from the pump the only one that I left stock luckily this caused a no start at home. I'm guessing it was from the accidental 20+ psi pull, and the ethanol eating through it once it bulged. Just glad it happened when it did.
                My new fuel pump wiring setup is 8 awg wire to st95 solenoid. The spade connections on a regular 50amp relay was melting. This is not the finished product still need to secure everything.IMG0972.JPG
                  How long did it take you to diagnose that? Thats never the first thing someone checks for unless you pulled the fuel feed first and saw no fuel coming out
                    Problem was discovered and fixed roughly in a hour including part store run for some hoes included. I have the rear seats out because I was cleaning them and applying leather conditioner. I couldn't here the pump kick. So I checked battery voltage, it was 11.7 so I gave it a boost and still same thing. I checked voltage at pump connector that was good, and pump ohmed out at 0.01 plugged in and put my ear right by it and could here fuel splashing like the return side normally makes so I pulled it and found the offender.
                    still need to figure out why my wastegate is not actuating, isolated the boost controller to rule that out but didn't get any further than that.
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      Hope you used submersible fuel line, not just fuel injection hose, or you'll have that problem again.
                        Thanks for making me paranoid about this.
                        I once had a surplus of fuel injection hose and I cant remember if I used that or the stuff that came with my Whinebro 255 when I installed it.
                          Thanks, I have some e85 safe line on order since the store didn't have any.
                            Went to go rip the car after being out of town for a few weeks, the gauges didn't power up, and found this guy posted up.IMG1128.JPG
                            my attempt to start the engine and scare him out simply put him back to resting.
                            I feel I had this coming for how much shit I give people at meets for having the secondary air injection pump in their cars.
                              All you need to do is hit boost down the road and that will make him faceplant out thee car.
                                  Shoot it
                                    Shoot it
                                    If he is there tonight I will be filming an execution on Facebook live.
                                      I need to see that shit
                                        OMFG. I almost died just seeing this. I cant wait to see the possum delete mod!!!
                                          Make sure you get him good!!  I attempted shooting one with my 20ga this summer and he seemed dead except his mouth was clamped shut so I blasted him again for good measure.
