540i Swapped Rat rod Build thread
yeah, do a 190s 328 homage grill for this thing, would be awesome.
The new style or old
I think he was referencing the 1936-40 328.
Yeah that's what I thought but either way I couldn't any on the Internet
How are things going with this, man?!?!
The further this thread goes the more confused I am as to why you ruined what appeared to be a good e30 shell
yeah old style 328. typo'd the date.
Yup. That was my thinking too.
Alright first off I'm sorry. There's been a lot of change of plans from my last post.
1st off I stopped posting in wi Bimmers because my 540 I swap wasn't going to go through. the guy I was going to get the car from turned into a real dickhead and didn't want to sell it to me.
So I started exploring other power train routes I ended up picking up an aluminum LS 5.3.
And between all of this I realize making my own frame was not possible to be street legal.
so I also started exploring other frame options.
I was able to find a 1936 Buick touring sedan frame that came with the title. So I purchased it and it is registered with the state and I now have a legal frame.
Progress photos
Currently the car is sitting on the frame and I am fabricating door jams.
During this process I have been designing a front control arm independent suspension.
The purchase items that I will be using with the suspension will be
-mustang style 2 pinto spindles
-5/8 hiems joints
-pinto ball joints
- QA1coil over shocks.
There will be custom control arms.
So the reason I am posting all this is because I finally got the 540 I E 34 from the guy I was trying to purchase it from.
So I have been pondering these ideas for a while and I believe I can make the get rag 420 transmission bolt up to the LS motor.
Therefore I will be able to use the driveline, the rear subframe, Differential, and control arms out of the 540 I
The reason I am not going to using the M60 Motor is because I am concerned about the reliability.
But this morning I purchase the car. Had to tow it to my house put some new gas in it checked all the fluids and a new battery and turned the key and it started right up.
Runs and idles and there's no codes all around it sounds really healthy.
So I still have many plans for it and it will get finished.
Love the update and the plans you have!
Steel or alum for the suspension?
I see two points in your design that I would do differently with your suspension design but overall it looks good! Have you calculated Ackerman angle or modeled in the roll centers? Just curious. I know this isnt a racecar but im fascinated with your build
The control arms will be tube steel.
I have accounted for some of the angles. I will be running a very stiff spring rate. With low travel. With taller profile tires. So the tires absorb most of the bumps.
This is the look I'm going for.
I will be setting this car up for auto cross.
Quick up date. Here is the car I picked up.
Another update.
I started making the standalone engine management wiring harness out of the oem harness.
Im shaving all the unnecessary plugs and wires off the harness.
What management are you planning on using? Wiring always sucks.
Stock Ecu and custom fuse box. Currently making one right now
Great progress and success today with my custom wiring box. I have an official standalone engine management system for my M60b40.
After reading a lot of wire diagrams and taking a step out of my comfort zone. it all worked out in the end. This is the first time I've done any really serious wiring on a car.
--Ill let the pictures do the talking
Before
After
