540i Swapped Rat rod Build thread
Better pictures. I havent had alot of time to look at the car.
But here is some rough body lines. And a front look. I hope your as excited as I am.
Did some work today got a wooden mock up frame done. no where close to done. But it's a start.
Today I started on the steel frame. Basing it off the wood proto type.
To make the bends I made slit cutts. To make it easy to bend.
Then I made an opps an over bend and welded a rail. So I re cut it open and bent it back
You should turn that massive front grill into a kidney grill.
Looking good so far! -
Looking good so far!I have been thinking about how I can add some bmw looks to this thing.
Up date:
I test fitted the body on to the frame today and I have to say it fitted very nicely. I have the front suspension picked out. I will be ordering that this week so I can get started on the front set up.
yeah, do a 1930s 328 homage grill for this thing, would be awesome.
yeah, do a 190s 328 homage grill for this thing, would be awesome.
The new style or old
I think he was referencing the 1936-40 328.
Yeah that's what I thought but either way I couldn't any on the Internet
How are things going with this, man?!?!
The further this thread goes the more confused I am as to why you ruined what appeared to be a good e30 shell
yeah old style 328. typo'd the date.
Yup. That was my thinking too.
Alright first off I'm sorry. There's been a lot of change of plans from my last post.
1st off I stopped posting in wi Bimmers because my 540 I swap wasn't going to go through. the guy I was going to get the car from turned into a real dickhead and didn't want to sell it to me.
So I started exploring other power train routes I ended up picking up an aluminum LS 5.3.
And between all of this I realize making my own frame was not possible to be street legal.
so I also started exploring other frame options.
I was able to find a 1936 Buick touring sedan frame that came with the title. So I purchased it and it is registered with the state and I now have a legal frame.
Progress photos
Currently the car is sitting on the frame and I am fabricating door jams.
During this process I have been designing a front control arm independent suspension.
The purchase items that I will be using with the suspension will be
-mustang style 2 pinto spindles
-5/8 hiems joints
-pinto ball joints
- QA1coil over shocks.
There will be custom control arms.
So the reason I am posting all this is because I finally got the 540 I E 34 from the guy I was trying to purchase it from.
So I have been pondering these ideas for a while and I believe I can make the get rag 420 transmission bolt up to the LS motor.
Therefore I will be able to use the driveline, the rear subframe, Differential, and control arms out of the 540 I
The reason I am not going to using the M60 Motor is because I am concerned about the reliability.
But this morning I purchase the car. Had to tow it to my house put some new gas in it checked all the fluids and a new battery and turned the key and it started right up.
Runs and idles and there's no codes all around it sounds really healthy.
So I still have many plans for it and it will get finished.
