  4. 540i Swapped Rat rod Build thread
91 Posts 14 Posters 1.6k Views 1 Watching
    Make sure you put a "dapper" sticker on the back window when its done
      yeah, do a 1930s 328 homage grill for this thing, would be awesome.
      • ThatRatRodProjectT
        ThatRatRodProjectT
        ThatRatRodProject
        yeah, do a 190s 328 homage grill for this thing, would be awesome.
        The new style or old
          I think he was referencing the 1936-40 328.
            1997 328i convertible
              ThatRatRodProjectT
              ThatRatRodProject
              Yeah that's what I thought but either way I couldn't any on the Internet
                This looks like its going to be a good one!
                  How are things going with this, man?!?!
                    The further this thread goes the more confused I am as to why you ruined what appeared to be a good e30 shell
                      yeah old style 328. typo'd the date.
                        ^I second that idea
                          Yup. That was my thinking too.
                            ThatRatRodProjectT
                            ThatRatRodProject
                            Alright first off I'm sorry. There's been a lot of change of plans from my last post.
                            1st off I stopped posting in wi Bimmers because my 540 I swap wasn't going to go through. the guy I was going to get the car from turned into a real dickhead and didn't want to sell it to me.
                            So I started exploring other power train routes I ended up picking up an aluminum LS 5.3.
                            And between all of this I realize making my own frame was not possible to be street legal.
                            so I also started exploring other frame options.
                            I was able to find a 1936 Buick touring sedan frame that came with the title. So I purchased it and it is registered with the state and I now have a legal frame.
                            Progress photos
                            Currently the car is sitting on the frame and I am fabricating door jams.
                            During this process I have been designing a front control arm independent suspension.
                            The purchase items that I will be using with the suspension will be
                            -mustang style 2 pinto spindles
                            -5/8 hiems joints
                            -pinto ball joints
                            - QA1coil over shocks.
                            There will be custom control arms.
                            So the reason I am posting all this is because I finally got the 540 I E 34 from the guy I was trying to purchase it from.
                            So I have been pondering these ideas for a while and I believe I can make the get rag 420 transmission bolt up to the LS motor.
                            Therefore I will be able to use the driveline, the rear subframe, Differential, and control arms out of the 540 I
                            The reason I am not going to using the M60 Motor is because I am concerned about the reliability.
                            But this morning I purchase the car. Had to tow it to my house put some new gas in it checked all the fluids and a new battery and turned the key and it started right up.
                            Runs and idles and there's no codes all around it sounds really healthy.
                            So I still have many plans for it and it will get finished.
                              Love the update and the plans you have!
                              Steel or alum for the suspension?
                              I see two points in your design that I would do differently with your suspension design but overall it looks good! Have you calculated Ackerman angle or modeled in the roll centers? Just curious. I know this isnt a racecar but im fascinated with your build
                                ThatRatRodProjectT
                                ThatRatRodProject
                                The control arms will be tube steel.
                                I have accounted for some of the angles. I will be running a very stiff spring rate. With low travel. With taller profile tires. So the tires absorb most of the bumps.
                                This is the look I'm going for.
                                I will be setting this car up for auto cross.
                                  This is sweet!! I am glad you are still hammering away on it even though you hit so many bumps so early in the process. James' F20 powered model A will always be a sweet build, if done right, I see this heading the same direction.
                                    ThatRatRodProjectT
                                    ThatRatRodProject
                                    Quick up date. Here is the car I picked up.
                                    29f7a5ace74d43d4bb4209ec96458643.jpg57cecddda9fe13ba48e87c8191a90d0b.jpg791b817c1fdb424af87a6db740fe9bab.jpg0caa29dcbaff8a556460af6843d0a9e0.jpg
                                      ThatRatRodProjectT
                                      ThatRatRodProject
                                      Another update.
                                      I started making the standalone engine management wiring harness out of the oem harness.
                                      Im shaving all the unnecessary plugs and wires off the harness.
                                      ba1c59ddd3e86bfd97b49bf7d3f34d59.jpg2438fadb8f0021e1f2163617d0b5cf26.jpg3c4e89e8760287e8746e0bcc71d0665a.jpg4087a5d23f9fe70529e0ec93edaee657.jpg9980d157162e66836a77241dfc34ef5e.jpga6a60475de3d5ac9608898a951fb2306.jpgc5b5df40509a7f833e02c60c25c4b6f7.jpg
                                        I wish you Godspeed
                                          What management are you planning on using? Wiring always sucks.
