  4. My life in the slow lane: Turning a z71 4x4 335I into something respectable.
335isingle turboxdriven54port injectiontwin turbovrsftialfuel-itcomp turboz71still not fast4x4does anyone eve
86 Posts 15 Posters 1.7k Views 2 Watching
    Chris is crazy...  We worked together in Dubuque and he knew I was into BMWs so he calls me after seeing this car at the local Toyota dealer and said something like "it looks cool are they pretty good cars?"  I said yea they are nice and decently reliable.  Now here we are...
    HAHAHA awesome.
      I don't think this pisses anyone off.  This should make 4 figure power if i'm figuring that correctly, right?
        " The new engine that will replace it will be a 427 cubic inch dart LS next block with two big snails hanging off of it "
        I would imagine that it will be well into four figures by the sounds of it!
        • i_love_carsI
          i_love_carsI
          i_love_cars
          Chris what do you think the timeline for everything is? Will this be ready for us to see next season?? I know you're using the iron block for testing purposes but are you just going to basically use it to get all the ECU controls and creature comforts sorted, and then blow it up so you can quickly move on to the new motor?
          2007 Z4MR
          2003 E39 M5
          2002 E46 M3
          2021 X5 40i
          • Chris WelterC
            Chris WelterC
            Chris Welter
            I am really hoping to make a couple passes on the 4L80e and the stock N/A 5.3 in the spring to set a baseline against my stock N54 timeslips. The turbo setup will come later as I have to select the turbos so I only buy one set and be done with it. The general idea right now for the engine is run the 5.3 and get some base times and tunes down so if I blow it up I'm out $500 instead of the new motor (which I'm having tuned). The other thing is the new motor will be $$$$ so it will buy me some fun drive time until I get the funds together to buy it. The initial power goal (hence bigger cube motor) is 1200 whp but we'll see how everything pans out as I don't plan on spinning it past 6500. Gotta make it worth the swap as the N54 is a powerful motor to replace 😜. Transmission will have a HD2 shift kit in it soon and will be upgraded to a Jake's performance level 5 when the new motor is ready. As for rear end, I already plan on shredding it so I've ran up some plans to beef up my subframe and control arms and also install a 9" ford DSS IRS conversion kit. Again reasoning is I want to maintain BMW designed suspension just stronger.
            Sent from my HTC6525LVW using Tapatalk
            2009 335XI: JB4, DCI, Tein Springs, Custom exhaust, Single Turbo, Port Injection, VRSF 7", ...
            2002 Suburban: DD and toy hauler.
            1996 Jeep Grand Cherokee: Come buy this I dont want it anymore!
            • Chris WelterC
              Chris WelterC
              Chris Welter
              Big hold ups right now are mechanical fuel pump surge system (jc43089 helped me through this one), stock LS intake and water pump, alternator mounting, and other small items besides the Ecu. I am heading over to get my oil pan setup today, so there is still progress.
                What intake manifold and water pump are you looking to run? Odds are, I know someone that has what you're looking for.
                • Chris WelterC
                  Chris WelterC
                  Chris Welter
                  For now just stock LS1 stuff for cars on the 5.3..
                  • Chris WelterC
                    Chris WelterC
                    Chris Welter
                    So yet another update. I got the motor to fit into the car and the second set of headers are installed (first set were too long). Motor is in with a motor plate and I spent a good amount of time freshening up gaskets and cleaning the test engine. I have learned you really have to wanna go fast to attempt to do this kind of swap. Engine is almost in completely and wiring will be fairly quick thanks to my Dominator harnesses and a spreadsheet I made of all the wires I need to modify for the oem harness. Going to make the tach and oem gauges work for the most part until I'm ready to drop the 7" Holley display in. Now some update pix.
                    Sent from my HTC6545LVW using Tapatalk
                    • Chris WelterC
                      Chris WelterC
                      Chris Welter
                      Overall progress of fitting motor and getting correct fitting headers. Motor cleaned in the pics and reassembled with new gaskets ect. Powder coated valve covers for a hint of color and a ls1 water pump. Now to just get it final mounted on the motor plates with the c5 corvette racing alternator and we are in business. e765b360dad257827ebc6d15aff8d367.jpg49d1e65d53639b88dc537e001c819cd6.jpgd5e12afdae0e29767a8955c9a8bc05cc.jpg44944a8cd159828ad328473b6d94bf2a.jpgb361c7f164b0bb2511a7693ca5b56a6d.jpg7f985d1f83c907b6bfd9420584a22779.jpgef70078c2ceaba57a31cf07cdf3f0576.jpge18d9ce6de607577f11320c61e440768.jpgd4e4745d9c41b893b9b4c699c732f684.jpg504fd17ca610e30ef49f931376473272.jpg
                        That motor looks badass!
                          Yes! Glad to see an update on this!!
                          • Chris WelterC
                            Chris WelterC
                            Chris Welter
                            Here's another shot as of recent.. Dominator is installed and wiring is ran. Put the front on to figure out the cooling and the turbo/exhaust situation. 5aae8dbf9a5148691d44107159b4e42a.jpge4b7ddd68f4d12e3875161aed98d6f8e.jpg
                            • i_love_carsI
                              i_love_carsI
                              i_love_cars
                              awesome progress. It looks like there is a light at the end of the tunnel now. Seems pretty plausible that this car will be running well before summer is done?
                              2007 Z4MR
                              2003 E39 M5
                              2002 E46 M3
                              2021 X5 40i
                                Nice update!
                                Access to the front of the engine looks improved over the I6 (obviously), Is there anything that is going to be a royal PITA to work on with this setup that will require pulling the engine, that normally wouldn't (spark plug access etc.)
                                  Awesome! Managing underhood temps looks like it's going to be your biggest enemy here.  I hope I get to see see this thing running one day!
                                  • Chris WelterC
                                    Chris WelterC
                                    Chris Welter
                                    That is the plan, I'd like to get it on the track at least once before it gets cold. The engine is almost there, just gotta get the trans and shift linkage in and get the d/s made. The exhaust can be really easy for the time being to just get it to run. Main obstacle with the turbos will be that radiator fan, but I have a few ideas to eliminate that issue.
                                    • Chris WelterC
                                      Chris WelterC
                                      Chris Welter
                                      Nice update!
                                      It really depends on how the exhaust and turbos all work out. The motor plate has been sheared and I can actually remove the plugs from the front of the engine (reach between the plate and the manifold to access them fairly easy). Compared to a C5 there is a lot of room and I could pull the intake manifold off or change oil or map sensors with engine in the car. The car being a prior Xi has a different front subframe that if the car is lifted there is HUGE access with the skid plate off. As of now I can't see a reason to pull the engine for anything really. It is truly impressive how it fit in there.
                                      • Chris WelterC
                                        Chris WelterC
                                        Chris Welter
                                        I have been thinking about that a lot recently and have been trying to come up with a solution. I thought about wrapping the headers since they are stainless but don't really want to deal with stressing the materials out with excessive heat and cracking them. It is looking like ceramic coating will be the best option but I've had crap luck with that in the past and it is rare it stays nice for long. Time will tell, might run them unfinished and insulate everything around them.. Hood louvers may be warranted..
                                          Whenever I do ceramic coating, I top coat them with high temp spray paint so that a) it protects the ceramic and b ) its quickly and easily touched up when it does get scratched.
