  4. My life in the slow lane: Turning a z71 4x4 335I into something respectable.
335isingle turboxdriven54port injectiontwin turbovrsftialfuel-itcomp turboz71still not fast4x4does anyone eve
86 Posts 15 Posters 1.7k Views 2 Watching
    Hexon 335i finally turned the boost up to 25psi recently. Beats me by a car or two now.
    The white twin-turbo G8 that I've ran a lot in the past also turned up the boost from 7psi to 12psi and puts a few cars on me.
    I met up with a stock looking MK4 Jetta this past weekend. Built motor and trans, Precision 6266 running 36psi, 93 octane + meth. Dyno shows 560whp and the interior is gutted. From a 60 roll it was neck to neck until I started to edge him out at about 120mph. I had a passenger, he didn't. He said he is also going to the 1/2 mile event this September so it should be a blast getting a few rematches in.
    /ricerreply
    • Chris WelterC
      Chris WelterC
      Chris Welter
      Well time for an update. Per the last bit of this thread it has entirely derailed and the project has changed directions. What I'm about to show you will piss off the masses and set this car into the first of its generation.
      Sent from my HTC6525LVW using Tapatalk
      2009 335XI: JB4, DCI, Tein Springs, Custom exhaust, Single Turbo, Port Injection, VRSF 7", ...
      2002 Suburban: DD and toy hauler.
      1996 Jeep Grand Cherokee: Come buy this I dont want it anymore!
      • Chris WelterC
        Chris WelterC
        Chris Welter
        • Chris WelterC
          Chris WelterC
          Chris Welter
          • Chris WelterC
            Chris WelterC
            Chris Welter
            My 335Xi is no longer a 335Xi. It's a LS swapped e92 with a 4L80E transmission and is rwd ONLY. I decided on motor plates and pulled all the stops on going fast. The engine is a 5.3 iron block that is my "test" engine, you know one I won't feel bad about flogging until it blows. The new engine that will replace it will be a 427 cubic inch dart LS next block with two big snails hanging off of it. Also for interested parties, swapping out to kirkey racing seats and removing all other seats/ deadener in this car will save you in the neighborhood of 400lbs (my current configuration)..yes I actually weighed it all. New engine sits 7" further back in he chassis and driveline sits 2" lower. And I have the interior electronics working without canbus issues.
            • Chris WelterC
              Chris WelterC
              Chris Welter
              Now that just need my Holley dominator Ecu, dash and other goodies to show up and a lot more work and it should drive n/a!!
              • Chris WelterC
                Chris WelterC
                Chris Welter
                A little back to back comparison from a friend's top mount N54 and my LS swapped car. Note the LS is running a truck water pump so the car version is a good amount shorter.. either way if you use the front of the strut tower in comparison to where it sits on the motors you get a good idea..
                  Wow that tucks in there great!  Good work.
                    Well I didn't expect that.
                      Chris is crazy...  We worked together in Dubuque and he knew I was into BMWs so he calls me after seeing this car at the local Toyota dealer and said something like "it looks cool are they pretty good cars?"  I said yea they are nice and decently reliable.  Now here we are...
                        If only the original owner could see what it has become.
                          HAHAHA awesome.
                            I don't think this pisses anyone off.  This should make 4 figure power if i'm figuring that correctly, right?
                              " The new engine that will replace it will be a 427 cubic inch dart LS next block with two big snails hanging off of it "
                              I would imagine that it will be well into four figures by the sounds of it!
                              • i_love_carsI
                                i_love_carsI
                                i_love_cars
                                Chris what do you think the timeline for everything is? Will this be ready for us to see next season?? I know you're using the iron block for testing purposes but are you just going to basically use it to get all the ECU controls and creature comforts sorted, and then blow it up so you can quickly move on to the new motor?
                                2007 Z4MR
                                2003 E39 M5
                                2002 E46 M3
                                2021 X5 40i
                                • Chris WelterC
                                  Chris WelterC
                                  Chris Welter
                                  I am really hoping to make a couple passes on the 4L80e and the stock N/A 5.3 in the spring to set a baseline against my stock N54 timeslips. The turbo setup will come later as I have to select the turbos so I only buy one set and be done with it. The general idea right now for the engine is run the 5.3 and get some base times and tunes down so if I blow it up I'm out $500 instead of the new motor (which I'm having tuned). The other thing is the new motor will be $$$$ so it will buy me some fun drive time until I get the funds together to buy it. The initial power goal (hence bigger cube motor) is 1200 whp but we'll see how everything pans out as I don't plan on spinning it past 6500. Gotta make it worth the swap as the N54 is a powerful motor to replace 😜. Transmission will have a HD2 shift kit in it soon and will be upgraded to a Jake's performance level 5 when the new motor is ready. As for rear end, I already plan on shredding it so I've ran up some plans to beef up my subframe and control arms and also install a 9" ford DSS IRS conversion kit. Again reasoning is I want to maintain BMW designed suspension just stronger.
                                  • Chris WelterC
                                    Chris WelterC
                                    Chris Welter
                                    Big hold ups right now are mechanical fuel pump surge system (jc43089 helped me through this one), stock LS intake and water pump, alternator mounting, and other small items besides the Ecu. I am heading over to get my oil pan setup today, so there is still progress.
                                      What intake manifold and water pump are you looking to run? Odds are, I know someone that has what you're looking for.
                                      • Chris WelterC
                                        Chris WelterC
                                        Chris Welter
                                        For now just stock LS1 stuff for cars on the 5.3..
                                        • Chris WelterC
                                          Chris WelterC
                                          Chris Welter
                                          So yet another update. I got the motor to fit into the car and the second set of headers are installed (first set were too long). Motor is in with a motor plate and I spent a good amount of time freshening up gaskets and cleaning the test engine. I have learned you really have to wanna go fast to attempt to do this kind of swap. Engine is almost in completely and wiring will be fairly quick thanks to my Dominator harnesses and a spreadsheet I made of all the wires I need to modify for the oem harness. Going to make the tach and oem gauges work for the most part until I'm ready to drop the 7" Holley display in. Now some update pix.
                                          Sent from my HTC6545LVW using Tapatalk
