Subframe and arms are all painted and I started assembling.Â
Condor bushings in and swaybar endlink bracket mounted
I am still looking for a small case diff cover without broken fins to replace my current one. I can then open the diff and see why it locks up at 3 1/8th turns either way now.Â
I also took some time Saturday removing bits from the underside of the rear to prepare for wire wheeling any surface rust spots and then cleaning for the Rust seal.
Repainted the brake shields on Friday
Also found why my diff wouldn't make a full rotation. I must have bent this trigger wheel when I pulled the flanges out and the assembly rested in the housing.Â
I also attached the trailing arms to the subframe, bolted on the calipers/rotors, and bolted the diff in.Â
Saturday I bolted the axles on
I then bent and installed the brake lines. I still need to get the clips to hold them tight to the trailing arms.Â
Besides that Sam and I picked this up as a project for her
And from the second picture you can see that removing that dust and keeping the paint nice will be a challenge=(Â
Get some form of a foam cannon to lift the dirt off before you hit it with a sponge.
Hmmm....if only there was something you could cover the car with.
It was dusty when it arrived so I didn't want to put a cover over dust and compound the issue=(
 Bay color really doesn't matter to me because I won't have it open for anyone to see unless there is a different motor ever. lol
if only you knew
if only you knew
So young and naive=P lol
your bay is so clean, you tucked the motor!
I don't have foglights anymore=) I've had foglight blanks. My headlights are plenty bright enough and foglights don't seem to last long before getting a rock through them=PÂ
#e36problems
