    Subframe and arms are all painted and I started assembling.
    Condor bushings in and swaybar endlink bracket mounted
    I am still looking for a small case diff cover without broken fins to replace my current one. I can then open the diff and see why it locks up at 3 1/8th turns either way now.
    I also took some time Saturday removing bits from the underside of the rear to prepare for wire wheeling any surface rust spots and then cleaning for the Rust seal.
      Repainted the brake shields on Friday
      Also found why my diff wouldn't make a full rotation. I must have bent this trigger wheel when I pulled the flanges out and the assembly rested in the housing.
      I also attached the trailing arms to the subframe, bolted on the calipers/rotors, and bolted the diff in.
      Saturday I bolted the axles on
      I then bent and installed the brake lines. I still need to get the clips to hold them tight to the trailing arms.
      Besides that Sam and I picked this up as a project for her 😃
        I was finally able to apply KBS Rust Seal and then undercoat.
          What if a street surgeon was using your car as an operating table because it was so clean? Then what would you do?
            I would question his idea of "clean"=) The car is covered in metal dust and saw dust currently=/
              Got back down on four wheels
                Just from that top picture you can get an idea at the quality of the paint job. OE paint jobs definitely dont show reflections like that
                  And from the second picture you can see that removing that dust and keeping the paint nice will be a challenge=(
                  • JasonMasonJ
                    JasonMasonJ
                    JasonMason
                    Get some form of a foam cannon to lift the dirt off before you hit it with a sponge.
                    1988 325i vert
                    2002 Jeep Grand Cherokee
                      Would hitting it with really soapy water be the way to go?
                      how much rage would there be if someone drew penises in the dust all over the car?
                        Hmmm....if only there was something you could cover the car with.
                          It was dusty when it arrived so I didn't want to put a cover over dust and compound the issue=(
                          • RamenNooblesR
                            RamenNooblesR
                            RamenNoobles
                             Bay color really doesn't matter to me because I won't have it open for anyone to see unless there is a different motor ever. lol
                            if only you knew
                              RamenNoobles said:
                              if only you knew
                              So young and naive=P lol
                              • RamenNooblesR
                                RamenNooblesR
                                RamenNoobles
                                your bay is so clean, you tucked the motor!
                                  "Engine tuck"
                                  https://m.facebook.com/story.php?story_fbid=10155822409920112&id=305901075111&refsrc=http%3A%2F%2Fwww.google.com%2F&_rdr
                                    Finally scored a foglight switch blank=)
                                      Ho will you turn your foglights on?
                                        I don't have foglights anymore=) I've had foglight blanks. My headlights are plenty bright enough and foglights don't seem to last long before getting a rock through them=P
                                          #e36problems
