    Hell yeah man! Glad to see you found the right bearings!
      New bearings and seals installed, broken bolts removed from stub axle, trailing arms cleaned and painted. Time to do a mock up of everything bolted together to figure out how much shorter I need the halfshafts to be.
      Figure I can cut an inch or 2 out of my bad halfshaft, put a metal pipe between it with some set screws to make an adjustable halfshaft. Then just play around with lengths until there is no binding in the cv joints for the entire trailing arm motion.
      Once the length is found I will then take the good half shafts to machine service in pewaukee to have them shortened and balanced.
        is the custom half-shaft length because of the diff or that euro half-shafts are unavailable?
          It is because of the diff. The medium case is wider than the small case, so the half-shafts need shortening. The euro and us models use the same half-shafts otherwise.
            Got everything mocked up and ready to measure up the halfshaft lengths needed.
            I went ahead and cut an inch out of the bad halfshaft which should be more than needed. Found that 1" black pipe fits right over the halfshaft like a glove (after grinding a nub or two off the shaft). So I drilled some holes, welded a few nuts and got some thumb screws. Now I have an adjustable length shaft to mock things up with.
              thats a clever way to measure!
              also, i'm glad someone else uses their living room/furniture as work space.
                Always! Keeps the parts from getting scratched or dinged and its a lot more comfy working inside than outside this time of year. 😁
                  I need to take a picture of my living room currently to display that same thing lol
                    I know that feel
                      My living room looked 1% like that at one point, that train of thought was shut down rather quickly...you're lucky haha
                        I know that feel
                        LOL best part of this is $$$$ on car parts taking priority over real living room furniture.
                        • andyhundleyA
                          andyhundleyA
                          andyhundley
                          I know that feel
                          Mitch you should probably put that gallon of strawberry milk in the fridge before it goes bad.
                              Haha! This is awesome
                                Yes! Don't want another pb&j incident to happen again.
                                  Started messing with the rear euro valance install this weekend. Using my brothers awesome snap-on body hammers and dollies I got some areas smoothed out on it. I think it will be easier once it's welded on the car. I went to sand down the edge of the car to bare metal for welding and ran into another Fat Bob curse.
                                  DAMN YOU FAT BOB!!!!
                                  Looks like he just chipped away some rust and bondo'd the hole shut. [emoji35] So I got in there and ground away all the bondo and proceeded to weld up the hole like it should of been in first place. Picture looks worse than in person. I basically built up weld beads and ground it flat to form the edge again for the valance to be welded to.
                                  Progress pic
                                  Then just for fun I tacked the valance on for how it may look. I need to take it off and get that edge flatter to fit against the car a lot better. Then from there I'll need to figure out the side pieces and it should be good to go.
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    I need to know, who is fat bob?
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      The horrible previous owner of this car. Dumb high school kid who lost his license, so he decided to do terrible work to the car I have been discovering since day one of owning it.
                                        Image result for damn it bobby
