  4. My 91 325i
My 91 325i
42 Posts 12 Posters 643 Views 1 Watching
    ENGINE + 5SPD TRANS ARE IN THE CAR!
    spent a good 10 hours on the car today.
    We installed a new steering flex disk and got the steering linkages all put back together. Installed new grommets on the brake fluid res. POR15'd the muffler brackets and drilled out the broken stud on one of them. Changed the rear main seal, installed the new oil pan with baffle and windage tray. The gaskets were being stupid so I am just running RTV and praying that it doesn't leak. The lightened flywheel, new clutch and pressure plate went on and then of course the transmission. Then the engine and trans went in the car.
    I got my new driveshaft this week. I did notice a hose that needs replacing so I need to get that, connect everything , add fluids, bleed brakes clutch and coolant, and get the M42 radiator to fit. I still need to weld a new bung for the wideband before the exhaust goes in.
    I expect to be driving the car next weekend !
      Congrats:) I expect to see pictures of this far far from your house in a week to show that you got it driving and done;)
        HECK YEAH!!!! Man I have to tell everyone that this car looks amazing in person. Everything is coming together perfectly and will be one mean machine. It's been a blast helping out on this project let me tell you. Hopefully I can get enough free time to help finish this beast up on Saturday. Can't wait to take a ride in it possibly this weekend!
          Any luck getting it out this weekend?
            ^ALMOST
            Bassboy3313 was helping me again this weekend (couldn't have made such progress without him, he has been a HUGE help).
            He was connecting hoses and wires in the engine bay while I was adding fluids, connecting the clutch line, mounting the shifter, the power steering pump and lines. We installed the new driveshaft, the exhaust heat shields, the M42 radiator, then I realized I got the wrong hose splice piece to make the M42 radiator work so we had to make a trip to the store. My father-in-law insisted that we take his 335i which caused us to arrive at the store much faster than we should have :cool:
            We then realized that another hose needed a splice and had to make yet another trip. I think if we didn't have the 2 unexpected trips to the store we would have finished it all in time on Saturday but the extra few days of downtime allows me to get the wideband bung welded in so im ready to rock for this coming Saturday.
            The good news is that the car fired right up once everything was connected so I can sleep well at night knowing that I didnt kink any wires too badly or get anything mixed up
            What's left:
            -Install hood
            -Bleed brakes + clutch
            -Bleed cooling system
            -Install front wheels
            -Install drivers headlights+grille
            -Put interior together
            -Mount exhaust
              great progress man. personally, i think the bottlecaps look right at home on a lowered e30. rock them with pride.
                I still cant believe how close we got to finishing everything up. Gah! Oh, and how freaking amazing it was to drive that 335i. :o
                  Check out my bunghole
                  Posted Image
                  Since the fuel rail inlet is nearest cylinder 1, cylinder 6 will have the greatest pressure drop and in theory will risk running the leanest. It is also just downstream of the stock H pipe where the factory O2 sensor reads from. The geometry change will help promote a little turbulence for more complete measurement and may get a whiff of the front bank of 3 cylinders in between pressure pulses. In a perfect world (when I build a fancy exhaust system) the wideband would be reading all 6 cylinders from an X or H pipe but I think the positioning is pretty optimal for the factory downpipe.
                  I painted the exhaust and let it molest a corrugated drain pipe for a bit and packed it up to get welded.
                  Posted Image
                  Still looking forward to having the project complete this Saturday.
                    Looking good as usual!!
                      Well kiddos! IT DRIVES!
                      The car is AWESOME! I feel like a man now that my man-pedal swap is complete. Another automatic E30 off the road.
                      Everything looks and feels and drives perfect! Just need to go back out, clean up the shop and check for leaks.
                        Congratulations;)
                        • Ryan...R
                          Ryan...R
                          Ryan...
                          Very nice!
                          Now you just gotta get to a damn meet!
                            WOOT!!! I cant wait to take a ride in it. All that hard work REALLY did pay off for this one. Congrats man! Looks amazing!
                            • H
                              H
                              hlzblz
                              Congrats man! Glad to see everything came together.
                                CLEAN CLEAN CLEAN!!
                                You should rock it without the hood for awhile to show that thang off!!
                                  I have been driving it around like that just for giggles. :cool:
                                  I will probably put the hood back on tonight so I can start driving it to work tomorrow.
                                    DeathByNissan55
                                    Yey, alright my Datsun vs your bimmer, let's do this !
                                      Posted Image
                                      Just dont blow the welds on your intake manifold.
                                        Ffffffffffuuuuuuuuuuuuuu!!!!!!!!!! :P
                                          get your butt off the computer and do your homework so we can wrench on your car this weekend
