  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
  • i_love_carsI
    i_love_carsI
    i_love_cars
    Installed the LSD in the 1er today. Wow what a difference. Not much else to say. Probably the best mod I could have done given the power the car is currently making.
    Out with the old
    In with the new
    2007 Z4MR
    2003 E39 M5
    2002 E46 M3
    2021 X5 40i
      Relatively simple swap?
      • i_love_carsI
        i_love_carsI
        i_love_cars
        yeah the driveshaft nut was a PITA - i had a 52mm wrench but I think it's 50mm nut, so I had to wedge a stubby flathead screwdriver in to keep from rounding the nut. With a big enough pipe wrapped around the wrench it came off eventually. Other than that it was a pretty straightforward install.
        Some of the DIYs online involve dropping the entire driveshaft out, removing the exhaust - that's crazy. I just dropped one exhaust hanger on the back, then the front-most hanger on the axleback was welded on to a small plate that was attached to one of the mounting bolts for the differential, so I just undid that (cuz i had to anyway) and was able to slide that part of the exhaust off to the side and balance it (as seen in the photos). Just bent the heatshielld back a bit and had easy access to drop everything.
        First time doing it on this car and getting factory torqued bolts undone taking my time I finished in about 5 hours. Now I think it could be done in half that time. Probably 1.5 hours if you have air tools ( i don't :(  )
        2007 Z4MR
        2003 E39 M5
        2002 E46 M3
        2021 X5 40i
        • i_love_carsI
          i_love_carsI
          i_love_cars
          Evo 3 short shifter installed last night.
          I cursed a lot. I stabbed metal plates in the shifter housing so hard with a screwdriver that sparks flew.
          I eventually got everything installed with my wife helping me.
          I now know why everyone says for the 135i it's a PITA to install an STS. The instructions call for removing the driveshaft carrier and midpipes which certainly would have made it easier but also would have taken way longer. It's rather unnecessary.
          2007 Z4MR
          2003 E39 M5
          2002 E46 M3
          2021 X5 40i
          • I love my E39I
            I love my E39I
            I love my E39
            Contemplated taking the car to the shop since its been in the driveway since june... but I didnt and replaced rear drum on the riced out neon instead
            Sent from my LG-LS970 using Tapatalk
            -Because Racecar-
              Where is your leak coming from? There has to be a gasket that didnt seal properly or something that was damaged during the refresh?
              • I love my E39I
                I love my E39I
                I love my E39
                Well ill be vagye, its somewhere in the front and not upper or lower hose. And not headgasket. And not overheating just leaking out once reaches optimal temp
                -Because Racecar-
                  You should be able to pinpoint the leak while it is running and then go from there. I am sure it is just a gasket that didn't seat well or something small.
                  • I love my E39I
                    I love my E39I
                    I love my E39
                    Hope so but i ran it for almost 30 mins and could not see the leak anywhere..
                    -Because Racecar-
                      I love my E39 said:
                      Hope so but i ran it for almost 30 mins and could not see the leak anywhere.. Sent from my LG-LS970 using Tapatalk
                      Idle for 30 or drive for 30?
                      • I love my E39I
                        I love my E39I
                        I love my E39
                        Idle for 30. With revs. And thats enough for the coolant to come leaking out under car.like steady drip/stream.
                        -Because Racecar-
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          Thermostat housing?
                          1988 BMW 528e - Need parts?
                          1996 Mazda Miata (SOLD!!!)
                          1996 BMW 325i (Donor car)
                          • mkoeppM
                            mkoeppM
                            mkoepp
                            I had a leak on my 95 E36 M50 that I chased down to one of the water pump bolts. Removed and applied gasket sealer (or something like it) re-install and never had another problem. I have a telescoping inspection mirror that I bought to see things that I normally cannot and found it that way. It's a cheap buy at Harbor Freight. I hate chasing leaks, rattles and other things. It does feel good when you do find it though.
                              Wired up the city lights.
                              Thanks to Matt at the Appleton e30 meetup for pointing these out to me. I had never heard of them, or known that my car had them.
                                Do the Euro and US spec E21s use the same harness and just have the feature disabled with sealed beams?
                                  I think they are at least a litte different. The low end cars with the singles are probably different from the duals as well. I don't think the euro cars have side-markers either.
                                  I took the parking light wire from the directions to power he city lights. I must have euro directionals as well because the only take a single filament bulb, but there are 3 wires at the connector.
                                  My grill and lights are an aftermarket setup made by Hella, which I think was intended as an upgrade for cars with singles, so nothing quiete plugs in the way it's supposed to.
                                  • I love my E39I
                                    I love my E39I
                                    I love my E39
                                    Ramze46 said:
                                    Thermostat housing?
                                    I thought so but Usually cracked thermostat housing caused overheating? Atleast it did when I changed it on the GFs focus. I will have to look into it when I get home tomorrow, worst case Ill just bring it in to work and have them fix it. But the riced out neon is already set up for last of its brake repairs first. 😕
                                    -Because Racecar-
                                      Not sure I correctly interpreted what you were asking the first time. The 7" euro lights are not sealed beam and do have city lights in them. The US lights are sealed beam with no city light. Not sure about the euro dual setup.
                                      Also of interest is that I'm told many of the newer cars that use the same parts worldwide have a spot in the light for the city lights, but they are not installed.
                                        I guess my question was if your car was pre-wired for city lights.
                                          I love city lights!  I made my own on my e36 and it's one of my favorite mods so far!
