  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
  • I love my E39I
    I love my E39I
    I love my E39
    Contemplated taking the car to the shop since its been in the driveway since june... but I didnt and replaced rear drum on the riced out neon instead
    Sent from my LG-LS970 using Tapatalk
    -Because Racecar-
      Where is your leak coming from? There has to be a gasket that didnt seal properly or something that was damaged during the refresh?
      • I love my E39I
        I love my E39I
        I love my E39
        Well ill be vagye, its somewhere in the front and not upper or lower hose. And not headgasket. And not overheating just leaking out once reaches optimal temp
        -Because Racecar-
          You should be able to pinpoint the leak while it is running and then go from there. I am sure it is just a gasket that didn't seat well or something small.
          • I love my E39I
            I love my E39I
            I love my E39
            Hope so but i ran it for almost 30 mins and could not see the leak anywhere..
            -Because Racecar-
              I love my E39 said:
              Hope so but i ran it for almost 30 mins and could not see the leak anywhere.. Sent from my LG-LS970 using Tapatalk
              Idle for 30 or drive for 30?
              • I love my E39I
                I love my E39I
                I love my E39
                Idle for 30. With revs. And thats enough for the coolant to come leaking out under car.like steady drip/stream.
                -Because Racecar-
                • RamRod E28R
                  RamRod E28R
                  RamRod E28
                  Thermostat housing?
                  1988 BMW 528e - Need parts?
                  1996 Mazda Miata (SOLD!!!)
                  1996 BMW 325i (Donor car)
                  • mkoeppM
                    mkoeppM
                    mkoepp
                    I had a leak on my 95 E36 M50 that I chased down to one of the water pump bolts. Removed and applied gasket sealer (or something like it) re-install and never had another problem. I have a telescoping inspection mirror that I bought to see things that I normally cannot and found it that way. It's a cheap buy at Harbor Freight. I hate chasing leaks, rattles and other things. It does feel good when you do find it though.
                      Wired up the city lights.
                      Thanks to Matt at the Appleton e30 meetup for pointing these out to me. I had never heard of them, or known that my car had them.
                        Do the Euro and US spec E21s use the same harness and just have the feature disabled with sealed beams?
                          I think they are at least a litte different. The low end cars with the singles are probably different from the duals as well. I don't think the euro cars have side-markers either.
                          I took the parking light wire from the directions to power he city lights. I must have euro directionals as well because the only take a single filament bulb, but there are 3 wires at the connector.
                          My grill and lights are an aftermarket setup made by Hella, which I think was intended as an upgrade for cars with singles, so nothing quiete plugs in the way it's supposed to.
                          • I love my E39I
                            I love my E39I
                            I love my E39
                            Ramze46 said:
                            Thermostat housing?
                            I thought so but Usually cracked thermostat housing caused overheating? Atleast it did when I changed it on the GFs focus. I will have to look into it when I get home tomorrow, worst case Ill just bring it in to work and have them fix it. But the riced out neon is already set up for last of its brake repairs first. 😕
                            -Because Racecar-
                              Not sure I correctly interpreted what you were asking the first time. The 7" euro lights are not sealed beam and do have city lights in them. The US lights are sealed beam with no city light. Not sure about the euro dual setup.
                              Also of interest is that I'm told many of the newer cars that use the same parts worldwide have a spot in the light for the city lights, but they are not installed.
                                I guess my question was if your car was pre-wired for city lights.
                                  I love city lights!  I made my own on my e36 and it's one of my favorite mods so far!
                                    ^I did the same when I had stock headlights=) I wired in the city light from my current set too. They look sooo good
                                      Nope. In the euro cars the parking lights at the front are wired to the city light instead of the directional. When adding them to a US car many people wire them so that both the city light and the directional come on.
                                      • X
                                        X
                                        xgeetx
                                        Excuse the noobie question, what exactly are city lights and what is the point?
                                          They are small bulbs that illuminate the light without having the headlights on.
                                          I have been told that it is for driving around in town in parts of Europe at night where there are street lights and using headlights in those towns is illegal at night. Don't quote me though
