  4. Cosmos Resurrection
Cosmos Resurrection
87 Posts 10 Posters 1.8k Views 1 Watching
    Great now I need to get my rear in gear on the clutch work, Mike here is building a whole car for the meet and I haven't finished mine for last years...
    • mkoeppM
      mkoeppM
      mkoepp
      I am not really "building" but am swapping parts and taking care of maintenance items at the same time. It is going slow due to other business that needs tending to. It's going pretty smooth and no problems yet.
      Today I am going to swap the spare tire and trunk carpet :). Oh yea, there is a weight back there too.
      • mkoeppM
        mkoeppM
        mkoepp
        I ran into my first problem Sunday. I knew it was not going to go all smooth and easy.
        As it turns out my 8/84 build date for my 533i uses the old style diff mount that was used on the E12 and 633's. All I need as a newer style diff cover.
        The 533 also uses a different sway bar in the rear. I think I can remove and weld the brackets to make it work. If I cannot I will be looking for a rear sway bar also.
        Things are not going as quick as I had planned. Have been working more hours the last few weeks and less time in the shop. I will make it to the meet but it may be in my Battle Bimmer (Seta aka Niles).
        I sure hope this does not turn into a "Winter Project" but if it does I will change the way it is going back together. Right now I am not painting everything like I would like to, just cleaning. This may change.
        Still stripping the 533i and hope to get it out of the shop soon. I am taking everything I can off of it for spare parts before going BMW heaven.
          I should have an extra 528e sway bar somewhere. i dont know the differences on the brackets though but mine would be off a '86.
          • mkoeppM
            mkoeppM
            mkoepp
            I have to do some checking. I am not sure if the sway bar is different but I know the brackets are. 82 - 9/84 had a different mount. I will get a few pics tomorrow night.
            • mkoeppM
              mkoeppM
              mkoepp
              I made some progress last night. I finally got everything set up for the pull.
              The the beast came out. The M30 is huge. I does not look that big in the engine bay. I love all 3.4 liters.
              I also picked up a used M5 clutch and pressure plate from TDC that will be going in and I will be keeping the old for a spare. The current clutch was replace 4,700 miles ago and is still like new :).
                progress is good! glad to see things moving along. Is it difficult/impossible to remove the M30 with the trans still attached?
                • mkoeppM
                  mkoeppM
                  mkoepp
                  I am not sure and have not researched to see if it has been done. It just seemed easier to drop the trans first. I was going to chop the radiator support out and pull both together but I could not take a saw to the car even if it is going to the yard. That's just me.
                    Dont scrap the core support, could sell that for $100 if its clean.
                    From what ive ready on mye28 its pretty difficult to get the m30 with trans in/out. Motor is much taller than a M20, needs more swing down low.
                    Mike the garage looks great! Must've sold the trans am and i like that plate on the wall :) that hoist is a tank.
                    • mkoeppM
                      mkoeppM
                      mkoepp
                      I pulled my first engine over 30 years ago with that hoist in my dad's shop. They don't make them like that anymore.
                      • mkoeppM
                        mkoeppM
                        mkoepp
                        Where do I cut to make it usable?
                          If you look at the parts diagram you can see how it should be cut off. Basically it will be flat across the back as you should cut it where it meets the inner fender.
                          Also I'd like the rear shift plate support off this! I could bring a dremel if you dont have one.
                          • mkoeppM
                            mkoeppM
                            mkoepp
                            I have a cutoff wheel that should work. I have not had much time but I should be able to get it off by Saturday. I will let you know.
                              Do you still plan to have this car running and driving for the meet Saturday?
                              • mkoeppM
                                mkoeppM
                                mkoepp
                                I wish :(
                                Responsibility has kept me out of the garage. I am working my butt off to keep it from becoming a winter project. All is good though. I have some transmission seals ordered. Once I drop the suspension and get the cosmos in the work bay it will all be downhill. Working with 30 year old rusted bolts is a challenge to say the least. PB blaster and time have made it possible.
                                • mkoeppM
                                  mkoeppM
                                  mkoepp
                                  I did get the support off last night.
                                    A mixture of acetone and ATF works very well for loosening bolts, and is cheap.
                                    The input seal and the shift rod seal on the trans is easy to do, the output shaft you need to pull the flange off, follow torque specs carefully when reinstalling, it is preloading the output shaft bearing.
                                    • mkoeppM
                                      mkoeppM
                                      mkoepp
                                      Just got my Snap-On torque wrench calibrated for this swap. I was disappointed  at the cost of $70. It did not feel right and that is why I sent it in. They did not state any repairs on the invoice but if feels spot on again :). I have used this same wrench for over 30 years and I don't know when my dad actually purchased it. We have always treated it with "kid gloves" and has worked great. I believe this is the first time it has been back to Snap-On.
                                      Thanks for the nut buster info. I have not heard of that before but am willing to try it. I think I have everything covered for this job but you know how that goes.
                                      • mkoeppM
                                        mkoeppM
                                        mkoepp
                                        I finally got this out of the north bay!
                                        I can see the light at the end of the tunnel.
                                        post-3341-0-77878200-1419260809thumb.jp
                                        post-3341-0-28062100-1419260799thumb.jp
                                        And moved this guy over :)
                                        post-3341-0-28839500-1419262721thumb.jp
                                          Yay! What's left on the to do's?
