  4. Cosmos Resurrection
Cosmos Resurrection
87 Posts 10 Posters 1.8k Views 1 Watching
  • mkoeppM
    mkoeppM
    mkoepp
    CYoung said:
    I should have an extra 528e sway bar somewhere. i dont know the differences on the brackets though but mine would be off a '86.
    I have to do some checking. I am not sure if the sway bar is different but I know the brackets are. 82 - 9/84 had a different mount. I will get a few pics tomorrow night.
    • mkoeppM
      mkoeppM
      mkoepp
      I made some progress last night. I finally got everything set up for the pull.
      The the beast came out. The M30 is huge. I does not look that big in the engine bay. I love all 3.4 liters.
      I also picked up a used M5 clutch and pressure plate from TDC that will be going in and I will be keeping the old for a spare. The current clutch was replace 4,700 miles ago and is still like new :).
        progress is good! glad to see things moving along. Is it difficult/impossible to remove the M30 with the trans still attached?
        • mkoeppM
          mkoeppM
          mkoepp
          I am not sure and have not researched to see if it has been done. It just seemed easier to drop the trans first. I was going to chop the radiator support out and pull both together but I could not take a saw to the car even if it is going to the yard. That's just me.
            Dont scrap the core support, could sell that for $100 if its clean.
            From what ive ready on mye28 its pretty difficult to get the m30 with trans in/out. Motor is much taller than a M20, needs more swing down low.
            Mike the garage looks great! Must've sold the trans am and i like that plate on the wall :) that hoist is a tank.
            • mkoeppM
              mkoeppM
              mkoepp
              I pulled my first engine over 30 years ago with that hoist in my dad's shop. They don't make them like that anymore.
              • mkoeppM
                mkoeppM
                mkoepp
                Where do I cut to make it usable?
                  If you look at the parts diagram you can see how it should be cut off. Basically it will be flat across the back as you should cut it where it meets the inner fender.
                  Also I'd like the rear shift plate support off this! I could bring a dremel if you dont have one.
                  • mkoeppM
                    mkoeppM
                    mkoepp
                    I have a cutoff wheel that should work. I have not had much time but I should be able to get it off by Saturday. I will let you know.
                      Do you still plan to have this car running and driving for the meet Saturday?
                      • mkoeppM
                        mkoeppM
                        mkoepp
                        I wish :(
                        Responsibility has kept me out of the garage. I am working my butt off to keep it from becoming a winter project. All is good though. I have some transmission seals ordered. Once I drop the suspension and get the cosmos in the work bay it will all be downhill. Working with 30 year old rusted bolts is a challenge to say the least. PB blaster and time have made it possible.
                        • mkoeppM
                          mkoeppM
                          mkoepp
                          I did get the support off last night.
                            A mixture of acetone and ATF works very well for loosening bolts, and is cheap.
                            The input seal and the shift rod seal on the trans is easy to do, the output shaft you need to pull the flange off, follow torque specs carefully when reinstalling, it is preloading the output shaft bearing.
                            • mkoeppM
                              mkoeppM
                              mkoepp
                              Just got my Snap-On torque wrench calibrated for this swap. I was disappointed  at the cost of $70. It did not feel right and that is why I sent it in. They did not state any repairs on the invoice but if feels spot on again :). I have used this same wrench for over 30 years and I don't know when my dad actually purchased it. We have always treated it with "kid gloves" and has worked great. I believe this is the first time it has been back to Snap-On.
                              Thanks for the nut buster info. I have not heard of that before but am willing to try it. I think I have everything covered for this job but you know how that goes.
                              • mkoeppM
                                mkoeppM
                                mkoepp
                                I finally got this out of the north bay!
                                I can see the light at the end of the tunnel.
                                post-3341-0-77878200-1419260809thumb.jp
                                post-3341-0-28062100-1419260799thumb.jp
                                And moved this guy over :)
                                post-3341-0-28839500-1419262721thumb.jp
                                  Yay! What's left on the to do's?
                                  • mkoeppM
                                    mkoeppM
                                    mkoepp
                                    Way to many things to list. I want to get it running soon but I am not in a hurry. Now that I have the room I need to give the 528e "Niles" some TLC. I plan upper control arms, diff mount and CSB just to keep it riding well. I have all the parts so it's just a matter of time. I just picked up a set of 15" BBS style ?? with really good tires. It rides like a totally different car!
                                    post-3341-0-02385900-1419353384thumb.jp
                                    post-3341-0-10247500-1419353390thumb.jp
                                      Glad to see an e28 on the road.
                                      Do all e28s have medium case or are some large case diffs?
                                      • RamRod E28R
                                        RamRod E28R
                                        RamRod E28
                                        Need a super eta brake booster?! I'm ur man!
                                        1988 BMW 528e - Need parts?
                                        1996 Mazda Miata (SOLD!!!)
                                        1996 BMW 325i (Donor car)
                                        • RamRod E28R
                                          RamRod E28R
                                          RamRod E28
                                          So you scrapped both the white and the blue e28s?!
