686 Posts 32 Posters 8.8k Views 3 Watching
  • ClassEC
    ClassEC
    ClassE
    The bolts above in the toe/camber kit came zinc coated from Ireland Engineering - I'm having some other stuff coated by a local company a family member manages.
      Yup, that's how I did it the first time, I don't have an air chisel, later I took a few parts to my neighbors auto shop and he just popped them out in 30 seconds.
        If you could PM me the name of their shop that would be great. I need to do some bolts.
        • ClassEC
          ClassEC
          ClassE
          Hit me up with a text John and we can get something arranged.
          My air chisel didn't budge those bushings - I'll see how it works on the diff bushing today.
          Final cleaning up of the subframe tonight in preparation for welding Saturday!
            Awesome=)
            • ClassEC
              ClassEC
              ClassE
              After a quick clean-up with some carb cleaner and rag:
              Test fitting the toe and camber adjustments. Sanded down most of the weld areas, just need to mark and oblong slots for adjustment!
              • ClassEC
                ClassEC
                ClassE
                Tyler up at Arc Asylum got this all done for me:
                ....and these guys came today:
                So not a bad day. Tomorrow is test fitting subframe, cleaning and painting, and starting reassembly.
                • ClassEC
                  ClassEC
                  ClassE
                  FedEx driver is gonna know me by name at this rate... More parts arrived today!
                    So shiny!  Very excited to see the end results.
                    • ClassEC
                      ClassEC
                      ClassE
                      Well..... That cleaned up much better then I thought with just carb cleaner:
                        You should try something less harsh like simple green, It's easier on your skin and gets stuff clean.  I use it 50/50 with water in my parts cleaner.  It's also significantly cheaper than cans of carb cleaner.
                          Nice work! This car is coming along quickly, can't wait to see it on the ground. Are you planning on bringing it to the e30 picnic?
                          • ClassEC
                            ClassEC
                            ClassE
                            Normally I would - but the underside of things had a weird yellow "film" (hard to describe - thin layer of cracked yellow hue something) that did NOT want to come off. Used a putty knife to scrape it off, then needed carb cleaner and a scotchbrite pad to clean off. Whatever it was, it wasn't corrosive because it didnt etch the aliminium or steel.
                            • ClassEC
                              ClassEC
                              ClassE
                              Yup! Hoping to have it driving in 2 weeks (if I really haul ass and everything works out perfectly maybe next weekend.... But things never seem to go that way for me).
                              My first BMW, first GTG of the season, and first time showing off the car (other then this build thread - there's no pictures of this car/build anywhere. It's been "radio silence" on Instagram and Facebook for me - most people don't have any idea what I bought when I sold my mk3).
                              Looking forward to it!!!
                                ClassE said:
                                Normally I would - but the underside of things had a weird yellow "film" (hard to describe - thin layer of cracked yellow hue something) that did NOT want to come off. Used a putty knife to scrape it off, then needed carb cleaner and a scotchbrite pad to clean off. Whatever it was, it wasn't corrosive because it didnt etch the aluminum or steel.
                                Yea that is some kind of wax, I have found that in a few places on my car too, some seem to have more than others, my e36 had it on the tops of the strut towers but not much underneath.
                                  ^That's cosmoline, it's for rust prevention.
                                  • ClassEC
                                    ClassEC
                                    ClassE
                                    Not a bad day today. Got the trailing arm bushings and diff bushings out, adjusted the coil heights to where I "think" they're gonna be, and did some much needed cleaning in the garage.
                                    Tomorrow night is installing all the brake lines and getting the new bushings in the rear end!
                                    • ClassEC
                                      ClassEC
                                      ClassE
                                      With the exception of the passengers line - all the original rubber lines came out like a friggen dream. Passenger front took alittle more elbow grease and my big boy panties to break loose (didn't help it was a bench/tri day so pushing was a chore). So all new stainless braided lines are installed!
                                      When we were bleeding some of the fluid out when disconnecting the rear lines - we pumped the brake pedal alittle bit. The passenger front piston had pushed itself out of the caliper - should I be concerned about it? It pushed back in relatively easily (what I consider to be adequate pressure to get back in). I'm thinking this is normal from pumping the brakes? I believe that was the only caliper disconnected from the carrier at the time (which is why the drivers didn't push out as well). Thoughts?
                                      • ClassEC
                                        ClassEC
                                        ClassE
                                        Another day - another delivery.
                                        Shooting to have the car on the ground - ready to drive by next weekend!!!
                                          It's so fun to get packages.
