    Previous owner brought the car to Wisconsin from Alabama... I'm having a really hard time finding anything I'd consider "rust" on this car.
    First "Southern Car" I've ever owned.... Still amazed every time I go in garage and turn a wrench how good of condition it's in!
      Spacers and stud/lugnut conversion parts ordered today - gonna work on cleaning up subframe some more tonight and removing subframe bushings.
      Wish me luck!
        Good luck! Best bet for knocking out bushings with the outer metal sleeve is an air chisel.
          How I did it:
          Paddle bit around center - remove center. Score outer sleeve with sawzall, drive flathead between subframe side and score - bend edges in. Hit with "fine adjustment tool" until reach desired result.
          First one took about 20 minutes (I didn't know there was a outer sleeve..... Shut up Earl) - second one took about 10 minutes.
          Basketball in the living room time with my 2.5 year old! More tomorrow night.
            Where do you get the bolts zinc coated?
              The bolts above in the toe/camber kit came zinc coated from Ireland Engineering - I'm having some other stuff coated by a local company a family member manages.
                Yup, that's how I did it the first time, I don't have an air chisel, later I took a few parts to my neighbors auto shop and he just popped them out in 30 seconds.
                  If you could PM me the name of their shop that would be great. I need to do some bolts.
                    Hit me up with a text John and we can get something arranged.
                    My air chisel didn't budge those bushings - I'll see how it works on the diff bushing today.
                    Final cleaning up of the subframe tonight in preparation for welding Saturday!
                      Awesome=)
                        After a quick clean-up with some carb cleaner and rag:
                        Test fitting the toe and camber adjustments. Sanded down most of the weld areas, just need to mark and oblong slots for adjustment!
                          Tyler up at Arc Asylum got this all done for me:
                          ....and these guys came today:
                          So not a bad day. Tomorrow is test fitting subframe, cleaning and painting, and starting reassembly.
                            FedEx driver is gonna know me by name at this rate... More parts arrived today!
                              So shiny!  Very excited to see the end results.
                                Well..... That cleaned up much better then I thought with just carb cleaner:
                                  You should try something less harsh like simple green, It's easier on your skin and gets stuff clean.  I use it 50/50 with water in my parts cleaner.  It's also significantly cheaper than cans of carb cleaner.
                                    Nice work! This car is coming along quickly, can't wait to see it on the ground. Are you planning on bringing it to the e30 picnic?
                                      Normally I would - but the underside of things had a weird yellow "film" (hard to describe - thin layer of cracked yellow hue something) that did NOT want to come off. Used a putty knife to scrape it off, then needed carb cleaner and a scotchbrite pad to clean off. Whatever it was, it wasn't corrosive because it didnt etch the aliminium or steel.
                                        Yup! Hoping to have it driving in 2 weeks (if I really haul ass and everything works out perfectly maybe next weekend.... But things never seem to go that way for me).
                                        My first BMW, first GTG of the season, and first time showing off the car (other then this build thread - there's no pictures of this car/build anywhere. It's been "radio silence" on Instagram and Facebook for me - most people don't have any idea what I bought when I sold my mk3).
                                        Looking forward to it!!!
                                          ClassE said:
                                          Normally I would - but the underside of things had a weird yellow "film" (hard to describe - thin layer of cracked yellow hue something) that did NOT want to come off. Used a putty knife to scrape it off, then needed carb cleaner and a scotchbrite pad to clean off. Whatever it was, it wasn't corrosive because it didnt etch the aluminum or steel.
                                          Yea that is some kind of wax, I have found that in a few places on my car too, some seem to have more than others, my e36 had it on the tops of the strut towers but not much underneath.
