  4. E28 SETA Build
E28 SETA Build
bmw e46 e28 jeebmw e46 e28 ran
240 Posts 16 Posters 4.1k Views 3 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    bfinley said:
    Holy shit, you weren't kidding that it was clean !
    Would I lie???  :rolleyes:
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
      Here's the photo album on the E28 Hitch http://smg.photobucket.com/user/SlickDizzy/library/BMW/Hitch?sort=3&page=1
        How do you plan on sizing the other turbo for the twin setup?
        How would one use the compressor maps for this?
          Thanks Chris!  So that is an OEM setup?
            I guess its not OEM but a euro dealer option Westfalia trailer hitch. Doing some research this exact hitch wouldn't work on a US car but the basic design is a good base for a custom one.
            Here is the BMW one, no idea how/where this one mounts underneath but it also has a rear strut tower brace. http://www.realoem.com/bmw/showparts.do?model=DC11&mospid=47220&btnr=71_0088&hg=71&fg=10
            • RamRod E28R
              RamRod E28R
              RamRod E28
              Thanks Chris you ARE da MAN!!! And anyone elses thoughts on twin td04 turbos on the seta? With low boost a big ass intercooler and have a y-pipe for the twins to go to the intercooler. I was thinking about angling the trubos back a n=bit and run small pod filters on each and rock the smaller hot side parts from earlier wrxs so dirt cheap good turbos. Next step is to get an e30 i cam and springs with harness and e30 megasquirt pnp so the stroker is gonna happen first then start hording parts for the twins after that. I bet me and mr menard can swap cams and springs and put in a wideband and guage in a fortnight. i want to see if the m20 seta will run lean with stock fuel components before going ham on a new harness and getting megasuirtle
              • RamRod E28R
                RamRod E28R
                RamRod E28
                Or this...
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    JAW=DROPPED!!!!
                      Compound FTW!!  Let's giver!!
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        Would compound work with 2 of the same turbos? I'm still considering running each turbo off 3 cylinders each so 1.35L per turbo
                          I know nothing about turbo installation, although I know that sizing is critical for a good outcome.  Just finding a random turbo is probably not going to be that great.  Do you know what it came from?  You could also sell it and use the money for a well designed setup.
                          Not trying to be a Debbie downer, it would just be disappointing to put all of the work into a setup that didn't really work very well.
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            The turbo I got came from a 2008 WRX which has a larger hot side to it being a 2.5 which means I could run just one but if i swap over to a smaller hot side from the 2.0 boxer turbo It could work as a twin setup or I may sell this and the intercooler im getting in hopes for a more sizable single turbo. I dont wanna go crazy with boost, just enough to get me around 300whp to have some more fun with wider tires.
                              In that case it may be similar enough engine size to work as a single, I would do that.  Should spool like a boss!  Is there a manifold available that will bolt to that?
                              • RamRod E28R
                                RamRod E28R
                                RamRod E28
                                I was thinking of getting a eBay turbo manifold and weld on a Subaru turbo flange so then I can just interchange between scooby turbos and making finding different turbos to upgrade to easy to find and cheap
                                • RamRod E28R
                                  RamRod E28R
                                  RamRod E28
                                  Someone copied me for plate mounting...
                                  • RamRod E28R
                                    RamRod E28R
                                    RamRod E28
                                    Now for a roof rack... was thinking wheels but might as well rock my bottlecaps till they are bald  :D
                                      I rocked my bottlecaps until the tires were junk, and then someone gave me some free tires so I ran those for another year before I got the contour reps.  I would recommend lots of burnouts to dispose of them lol.  After looking at that turbo, the hot side inlet might be a standard pattern, I have a shiny downpipe that might fit, let me dig around the basement a bit.
                                        Don't mess around with a subie turbo man, unless you are doing some cool compound setup. The larger of the two turbos in a compound setup should be sized for your total power level.
                                        This is an m20 no? Just stick with the hx35 thing. Works well can't go wrong and its cheap.
                                        • RamRod E28R
                                          RamRod E28R
                                          RamRod E28
                                          So what does one do the night before scooters with a rusty as hell rear valance with the daylight dwindling??? YES!!! lets fix that valance and get her looking sharp!?!? Let's do some body work they said, it'll be fun they said...
                                          not a great before shot but you can see what I had to deal with...
                                          095EC948-C7D8-47E1-8302-792320A5C15Ezps
                                          finally getting somewhere after fabbing patches and grinding for like 2 hours with the new Bosch grinder! Mi padre and some classy beer were helping
                                          51002C3E-741D-4FD7-BE30-2D53E78AEE83zps
                                          9C7B7AA8-7B02-45EA-9A4B-321CFD988EA6zps
                                          Finally ready for some spray bombing!
                                          DF61F5D7-03D9-4116-A039-674847EAE891zps
                                          7C608AED-5FA9-4AE2-8A55-B6C89B732E89zps
                                          no more bumper mount holes!
                                          B869C864-C894-4CA8-9F52-86132526A66Dzps
                                          Then just to get her done for now some plastidip (it was almost 4am when I left the shop! Thanks again Dad!)
                                          CBB807EE-65D9-4E18-B960-09DC427312ECzps
                                          Also if you have manual seats you have a cupholder!
                                          0202FEC4-B355-451E-A1B8-EE0AFA2E3494zps
