  4. E28 SETA Build
E28 SETA Build
bmw e46 e28 jeebmw e46 e28 ran
240 Posts 16 Posters 4.1k Views 3 Watching
    Compound FTW!!  Let's giver!!
    • RamRod E28R
      RamRod E28R
      RamRod E28
      Would compound work with 2 of the same turbos? I'm still considering running each turbo off 3 cylinders each so 1.35L per turbo
      1988 BMW 528e - Need parts?
      1996 Mazda Miata (SOLD!!!)
      1996 BMW 325i (Donor car)
        I know nothing about turbo installation, although I know that sizing is critical for a good outcome.  Just finding a random turbo is probably not going to be that great.  Do you know what it came from?  You could also sell it and use the money for a well designed setup.
        Not trying to be a Debbie downer, it would just be disappointing to put all of the work into a setup that didn't really work very well.
        • RamRod E28R
          RamRod E28R
          RamRod E28
          The turbo I got came from a 2008 WRX which has a larger hot side to it being a 2.5 which means I could run just one but if i swap over to a smaller hot side from the 2.0 boxer turbo It could work as a twin setup or I may sell this and the intercooler im getting in hopes for a more sizable single turbo. I dont wanna go crazy with boost, just enough to get me around 300whp to have some more fun with wider tires.
            In that case it may be similar enough engine size to work as a single, I would do that.  Should spool like a boss!  Is there a manifold available that will bolt to that?
            • RamRod E28R
              RamRod E28R
              RamRod E28
              I was thinking of getting a eBay turbo manifold and weld on a Subaru turbo flange so then I can just interchange between scooby turbos and making finding different turbos to upgrade to easy to find and cheap
              • RamRod E28R
                RamRod E28R
                RamRod E28
                Someone copied me for plate mounting...
                • RamRod E28R
                  RamRod E28R
                  RamRod E28
                  Now for a roof rack... was thinking wheels but might as well rock my bottlecaps till they are bald  :D
                    I rocked my bottlecaps until the tires were junk, and then someone gave me some free tires so I ran those for another year before I got the contour reps.  I would recommend lots of burnouts to dispose of them lol.  After looking at that turbo, the hot side inlet might be a standard pattern, I have a shiny downpipe that might fit, let me dig around the basement a bit.
                      Don't mess around with a subie turbo man, unless you are doing some cool compound setup. The larger of the two turbos in a compound setup should be sized for your total power level.
                      This is an m20 no? Just stick with the hx35 thing. Works well can't go wrong and its cheap.
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        So what does one do the night before scooters with a rusty as hell rear valance with the daylight dwindling??? YES!!! lets fix that valance and get her looking sharp!?!? Let's do some body work they said, it'll be fun they said...
                        not a great before shot but you can see what I had to deal with...
                        095EC948-C7D8-47E1-8302-792320A5C15Ezps
                        finally getting somewhere after fabbing patches and grinding for like 2 hours with the new Bosch grinder! Mi padre and some classy beer were helping
                        51002C3E-741D-4FD7-BE30-2D53E78AEE83zps
                        9C7B7AA8-7B02-45EA-9A4B-321CFD988EA6zps
                        Finally ready for some spray bombing!
                        DF61F5D7-03D9-4116-A039-674847EAE891zps
                        7C608AED-5FA9-4AE2-8A55-B6C89B732E89zps
                        no more bumper mount holes!
                        B869C864-C894-4CA8-9F52-86132526A66Dzps
                        Then just to get her done for now some plastidip (it was almost 4am when I left the shop! Thanks again Dad!)
                        CBB807EE-65D9-4E18-B960-09DC427312ECzps
                        Also if you have manual seats you have a cupholder!
                        0202FEC4-B355-451E-A1B8-EE0AFA2E3494zps
                          bfinley
                          After picture?!
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            5CA5B843-C823-4D9D-9081-447504461140zps
                              bfinley
                              I liked the rust...
                              • RamRod E28R
                                RamRod E28R
                                RamRod E28
                                bfinley said:
                                I liked the rust...
                                you would haha
                                  bfinley
                                  I liked the rust...
                                    Is that spray foam?  Or what did you fill the hole with?  It looks great BTW.
                                    • RamRod E28R
                                      RamRod E28R
                                      RamRod E28
                                      metal behind the holes and body filler over it all sculpted to the body lines. (i need bigger twin tips now lol)
                                      • RamRod E28R
                                        RamRod E28R
                                        RamRod E28
                                        Also met mkoepp when I was chilling with cyoung and after hanging out with the other e28 mike chris and I headed to lake michigan for a few e28 shots!
                                        7CAFD2EC-DB63-4635-B7E5-81779EF2E7F9zps
                                        59E4693A-5EA1-485C-8B70-3BFE028AD766zps
                                        Rocking bottlecraps!
                                        AA48C022-395E-4838-BA27-B535A641D851zps
                                        2FB59D4B-45CC-4A43-99B0-F82242F12372zps
                                        F8D41966-56FB-4928-B331-51EB0450BF8Dzps
                                        163F6B76-184A-489D-BF29-C43824C37394zps
                                        B2ABCF7D-2874-44AC-A1CB-F5A60FDAC83Azps
                                        Represent!
                                        CC351602-C1D1-4507-8273-77C09D05DED8zps
                                        B1F64965-8855-4425-BD33-26A9CA7FBCFDzps
                                        51EA099C-DFF2-4944-933A-3438CC0AEF96zps
                                        5E5DE0B1-37C9-4729-9741-8615C9065543zps
                                        F523EC5F-8F7D-4869-AFFA-5DF6EBFD6DC7zps
                                        925ABB04-92C8-466F-B24D-29E3B8291A76zps
                                        She's a dirty girl!
                                        4FE3C089-FC70-4006-96DE-7F78329E9B80zps
                                        A6295876-7101-49E3-8DDD-E8C3C3422741zps
                                        D6160DB1-E8C4-4BFF-BE4D-FD08093BAA87zps
                                        29516A41-9B9F-44FC-AD29-0611F8E33DC9zps
                                          Sweet pics!
