1.6k Posts 49 Posters 1 Views 1 Watching
    Sent from my SCH-I535 using Tapatalk 2
      very very nice!  That must be really exciting! The afrs look nice and stable/consistent too. What psi is this at?
        Thanks!! You have no idea on how nervous I was!
        The afrs were so rich most of the time they flat lined at the bottom. There is some tuning to do but TRM probably runs their tunes super rich due to lawsuits. I'll see what they have to say Monday. Or I might just put more boost on it!
        I had a 15lbs spring in the waste gate. I'm going to run that until I sort out my high rpm issues.
          very cool :cool:
          cool to see all that hard work pay off eh?
            very cool :cool:
            It was a great day! I was almost turning green in the face when it was the moment of truth.
              I gapped my plugs from .030 to .025. Hopefully this will help the cause. They all looked the same except for cylinder #1 which was a little oily. #ohgod
              I'm guessing that it is due to a lack of CCV and pressure is building up at the front of the motor because the stock CCV is as big as a pencil.
              I'm dropping off the car on Monday to get the exhaust work done.
                nooooooo!!! hood exit needs to stay!!
                Sent from my piece of shit laptop using the internet
                  LOL
                    LOL
                    Haha
                      Update:
                      The car is currently at the exhaust guys shop. Let the welding commence! I'm going 3" stainless all the way back to a straight through 3" in/out borla muffler. I'm getting a flex pipe welded into the downpipe along with 2 O2 sensor bungs and my one way valve for the CCV vacuum. V-band will connect the downpipe to the rest of the exhaust.
                      Once I get the car back I'm going to port and tap the valve cover for the CCV. Then we should be good!
                      As for the tune I'm in contact with TRM. I'm going to pressure test the system to be 100% sure I don't have any leaks then see what they can do to adjust the AFR.
                        DrLeadFoot said:
                        Update:
                        What wideband sensor/controller are you getting?
                        If you get an Innovate LC-1/MTX-L you can run a simulated narrowband signal to the stock ecu which is more accurate than the narrowband. When I still had a Motronic ECU, I did this and it ran the best it ever did until it saw an extra 0.1V from the o2 sensor that it wasnt expecting and threw a CEL. That was before I figured out how to adjust the output values though. They can be adjusted to make sure they dont go out of limits for what the ECU is expecting to see.
                          Update:
                          I have the PLX Devices unit. It looks pretty smart. Do you know if this is capable of the same thing?e5yjabyn.jpg
                            I like the mudflaps, what brand are they?
                              http://www.plxdevices.com/AppNotes/PLXApp004.pdf
                                What resistor do you have to use?
                                Sent from my SCH-I535 using Tapatalk now Free
                                  Kamotors made them. He is on r3vlimited.com
                                    I am not even going to go there on this one!
                                      Are they hard plastic?  They look stiff, I have rallyarmor urethane ones and they are nice and bendy.
                                        I never ran a resistor, but since I run Megasquirt now, I have no need to run simulated narrowband.  I'd try it without a resistor first if you are going to give it a shot.
                                          Bad experience? He has always been good with my transactions.
