pistonse30
    I run 3 gauges in my center vent, fits perfectly and has a nice clean look, not sure what you have there.
    Get an s54 oil filter housing, way cheaper. You can get them new for like $370 if you really wanted something new.
    All you have to do it is drill out the ports a smidge, run a 3/8NPT tap into them and put a 3/8NPT - 10AN adapter in. Run the lines to the cooler of your choice.
    The S54 housing has a built in thermostat so you do not have to worry about adding one externally. Mine solved my 250+ degree oil issues!
    Do you have oil temp issues right now? Two coolers may be overkill, I have a pretty small one and it works just fine!
      http://www.podi.ca/VentPackages.aspx?CarID=15
        They make a nice gauge!  My brother in law has it in his A6 and loves it!
          There are mixed reviews of those on the e30 forums, a lot of people have major issues with them, and others have good luck.
          I think they are awesome, but killer expensive!
            That's cheap...
              Yea, that's a good deal for a digital gauge
                I mean, I pay that sort of money for mirrors or other pointless aesthetic mods haha
                  Got the head off. There is some detention on the pistons... The head gasket wasn't bent or broken but the #2 piston looked like it was the problem. Pics to come in the morning.
                  Frank Smith offered to give me the software to make my own chips and Todd of TCD has the hardware to make the chips. I need a good tune!!!!!!
                    Pics of the carnage.
                    -There is some detonation.
                    -Cyl #1 had a leaky injector for awhile.
                    -The tune has been super rich.
                    -I have some port matching todo.
                    Zipties for the documentation
                    I will be ordering a cut ring gasket, new arp head studs, exhaust nuts and researching the best exhaust manifold gasket today.  Also, I will take the head into the shop to have it inspected then after it checks out I'll get it back to port match everything then send it back to get cleaned up.
                      Ordered everything on this list under E30 except the head studs and cutring gasket. Also got a new oil temp & pressure gauge with matching sending units.
                        Does that mean the ARP's for sure stretched?
                          Not sure but don't want to risk it at all.
                            You didn't like the Podi gauge I assume?
                              Not for me. Like the classic look
                                for science reasons could you measure them?
                                  I definitely will and if they look good I'll sell them for cheap.
                                    DrLeadFoot said:
                                    I definitely will and if they look good I'll sell them for cheap. Sent from my SM-G900V using Tapatalk
                                    keep me in mind! thanks.
                                      http://www.bimmerforums.com/forum/showthread.php?2189060-CES-Motorsport-BMW-E36-High-Boost-Cut-Ring-Headgasket-Sale
                                        Make note of this part of that post: Remember... no gasket can hold up to a bad tune, so make sure that your tuning is solid and dyno tested, and let's keep pushing the limits of the E36 platform!
                                          My attention has been on my bathroom remodel but that will be wrapped up next week. I'll be port matching the exhaust ports, turbo flange and turbo then taking it back to the machine shop.
