pistonse30
    It is doubtful that you would have much success with other bearing caps since they are machined as a unit with the head and even running the caps that are mounted in the wrong location (originally machined for exhaust cam bearing #3 but using it on intake cam bearing #3) can be problematic
    When I was 17 I found this out the hard way when using a bearing cap from another engine and not being able to turn the engine over even with the bearing cap well under-torqued at 15ft-lb.
    I would scotch brite the scuff lightly to help knock down the edge a little and just not worry about it remembering that even at 7000 rpm your cams are only turning 3500 and arent under nearly the same load as the bearings on the crank.
      Man that is nasty! Looks like a milkshake that I would not be interested in drinking!
        It wasn't all that bad from other pictures I've seen.
        I talked to John and ECS and he said he has sold hundreds of these head gaskets and hasn't had one customer come back with a complaint.
        Link to head gasket info: http://www.cesmotorsport.com/documents/94.html
        Oil cooler ideas w/ links.
        Oil cooler cap: http://www.rallyroad.net/content/oil-cooler-cap
        Thermostat: http://www.summitracing.com/parts/ctr-22-480/overview/
        Cooler(s): https://www.cantonracingproducts.com/cgi-bin/commerce.cgi?search=action&category=2350
               - Not sure of what to do with the cooler size.  I haven't measured anything yet but thinking I could run two of the smaller Canton coolers in tandem behind and to the left and right of the kidney.
        Or do I just go S54 oil cooler and call it a day?
          Ideas of where to mount another gauge?  Don't want to do the A-pillar.
            I don't know if it would work but the upper center vent would be a prime spot in an e30. I've also heard great things about the CES cutring gaskets.
              I'm probably going to go with a single gauge in the left center vent.
                I run 3 gauges in my center vent, fits perfectly and has a nice clean look, not sure what you have there.
                Get an s54 oil filter housing, way cheaper. You can get them new for like $370 if you really wanted something new.
                All you have to do it is drill out the ports a smidge, run a 3/8NPT tap into them and put a 3/8NPT - 10AN adapter in. Run the lines to the cooler of your choice.
                The S54 housing has a built in thermostat so you do not have to worry about adding one externally. Mine solved my 250+ degree oil issues!
                Do you have oil temp issues right now? Two coolers may be overkill, I have a pretty small one and it works just fine!
                  http://www.podi.ca/VentPackages.aspx?CarID=15
                    They make a nice gauge!  My brother in law has it in his A6 and loves it!
                      There are mixed reviews of those on the e30 forums, a lot of people have major issues with them, and others have good luck.
                      I think they are awesome, but killer expensive!
                        That's cheap...
                          Yea, that's a good deal for a digital gauge
                            I mean, I pay that sort of money for mirrors or other pointless aesthetic mods haha
                              Got the head off. There is some detention on the pistons... The head gasket wasn't bent or broken but the #2 piston looked like it was the problem. Pics to come in the morning.
                              Frank Smith offered to give me the software to make my own chips and Todd of TCD has the hardware to make the chips. I need a good tune!!!!!!
                                Pics of the carnage.
                                -There is some detonation.
                                -Cyl #1 had a leaky injector for awhile.
                                -The tune has been super rich.
                                -I have some port matching todo.
                                Zipties for the documentation
                                I will be ordering a cut ring gasket, new arp head studs, exhaust nuts and researching the best exhaust manifold gasket today.  Also, I will take the head into the shop to have it inspected then after it checks out I'll get it back to port match everything then send it back to get cleaned up.
                                  Ordered everything on this list under E30 except the head studs and cutring gasket. Also got a new oil temp & pressure gauge with matching sending units.
                                    Does that mean the ARP's for sure stretched?
                                      Not sure but don't want to risk it at all.
                                        You didn't like the Podi gauge I assume?
                                          Not for me. Like the classic look
