pistonse30
    Got the clutch on, loc-tit'd and torqued.
    Got a snap-on torque wrench.  LOVE IT
      Looks nice!!!!! Cant wait to see it back in action.
        Getting close!
        I need to look up how to prep the trans for install.  Where to grease and with what.
          How much did the torque wrench run you? I need to invest in a quality one like that=)
            It was around $480 with a discount.
              I prepped the trans for install last night.  Took some 0W oil and sloshed it around in the trans to flush it out a bit. Here are the results of the first and second flushes.
              First go.
              About half as much debris on the second round.
              My custom trans stand.
              After this I tired to get the trans in but could only get past the first clutch disk.  I need to pull the pressure plate and re-align the disks while slightly applying upward pressure during tightening.  This should solve the issue and if not I'll get my buddy over to muscle it in.  #getthebillytool
              • CMartC
                CMartC
                CMart
                What is the part on the left?
                Excursion 7.3
                E30 LS1
                  The brass clutch fork pivot pin?  and the metal wire piece is what hold the fork tight against it.
                    Had to take the pressure plate off and re-align the clutch disks after wrestling with the trans and not getting it to the honey hole. I had a couple buddies swing by for some beers, NCAA ball and a little wrenching.
                    Melted the red loc-tite to remove the nuts when the studs came out. Reinstalled the studs with blue loc-tite and snugged them in. We then cleaned up the threads with a wire brush and a pick for the install.
                    After a ton of finessing she popped in!
                      I dig the pretty pics
                        Thanks! This new lens makes me look like a pro. I am heading down to Chicago for an e30 spring meet up this Saturday with my e30. On the 6-8 hour to-do list that will get me on the road: - shift linkage, evo3 short shifter and Dssr - trans mount with stock e21 bushings - driveshaft     - take e36 CSB off and install new e30 OEM CSB. - install diff - install new OEM drivers door b-pillar latch and make it workable (door currently does not shut). - install new t3 gasket on the turbo. The current one blew out. - DRIVE!!!! .
                          Took a wire wheel to my drive shaft to clean off the rust and put a coat of rust treatment on it. Flat black rattle can to come tomorrow.
                          Getting my linkage ready for the Evo3 shifter.
                          Popped the turbo off.
                          To fix this
                          New drivers latch and torx bolts mounted.
                          Is this my Central Locking Unit that has the internals exposed?
                          Any idea where this wire/plug goes?
                          What about this white/red wire? In drivers kick panel.
                          Thanks for looking!
                            I have a silly question. Will sanding and painting the driveshaft affect it's balance?
                              Definitely not silly. I'm taking it to A-1 drive-shadt in Stallis after it gets the final coat of paint. Might as well make sure.
                                Any insight to the central locking unit and wires would be greatly appreciated.
                                  For shits and giggles I looked it up on google and the first hit was a v8 buick forum. They have done it without issues so it must be good=P
                                    Got the e36 drive shaft painted up and the e30 CSB on it.
                                    Comparison pictures of the e30 and e36 DS:
                                    Painted. Zipties FTW!
                                    Ready to go!
                                    On to the Evo 3 Shifter.
                                    The clip of the beeeaches.
                                    Had to use a vice grips to get it installed.
                                    New rear mount.
                                    Top side c-clipped in.
                                    New ZHP Knob to top it off.
                                      Fancy!  The DSSR is what makes it good.
                                        That should be coming in the mail tomorrow.
                                          I have bad news. The dssr will not fit on that selector rod joint as is. You need to sand the integrated bushings
