    It is a shot from the door cavity side of the exterior door handle.  There is a contact switch that closes when you pull up on the handle illuminating the interior lights.
      Did a little bit of work on the car but need to get into the office and do some work and get paid!
      Removing the rear main seal.
      Slide hammer'd it out.
      New rear main installed.  I put a thin layer of black RTV sealant on the outside and some oil on the inside.
      All torqued down to 80ft/lbs per UUC instructions.
        lol at the ziptie method
          Excited to hear how the twin disc feels driving. Genius design.
          Sent from my potato phone
            I'm all about those ties!!
              I ordered my last bit of parts that should be here Wednesday.
              Tomorrow I will get the clutch bolted up and move my attention to the trans and prep it for install.  Shift fork, brass pivot thing, new reverse switch and plug and wiring that goes with that.  I've never had reverse lights!
              Turbo t3 gasket needs to be replaced.  Any recommendations on a good one?
              I don't see why I couldn't get this on the road by this weekend.  Once it is under its own power I'm taking it to Dan the Exhaust Man's shop right away and having the e36 twin diff mount cover installed (if someone will take my money!).
              Also need to take some material off of my blow-off valve spring to stop the fluttering.
              /rambling
                Got the clutch on, loc-tit'd and torqued.
                Got a snap-on torque wrench.  LOVE IT
                  Looks nice!!!!! Cant wait to see it back in action.
                    Getting close!
                    I need to look up how to prep the trans for install.  Where to grease and with what.
                      How much did the torque wrench run you? I need to invest in a quality one like that=)
                        It was around $480 with a discount.
                          I prepped the trans for install last night.  Took some 0W oil and sloshed it around in the trans to flush it out a bit. Here are the results of the first and second flushes.
                          First go.
                          About half as much debris on the second round.
                          My custom trans stand.
                          After this I tired to get the trans in but could only get past the first clutch disk.  I need to pull the pressure plate and re-align the disks while slightly applying upward pressure during tightening.  This should solve the issue and if not I'll get my buddy over to muscle it in.  #getthebillytool
                          • CMartC
                            CMartC
                            CMart
                            What is the part on the left?
                            Excursion 7.3
                            E30 LS1
                              The brass clutch fork pivot pin?  and the metal wire piece is what hold the fork tight against it.
                                Had to take the pressure plate off and re-align the clutch disks after wrestling with the trans and not getting it to the honey hole. I had a couple buddies swing by for some beers, NCAA ball and a little wrenching.
                                Melted the red loc-tite to remove the nuts when the studs came out. Reinstalled the studs with blue loc-tite and snugged them in. We then cleaned up the threads with a wire brush and a pick for the install.
                                After a ton of finessing she popped in!
                                  I dig the pretty pics
                                    Thanks! This new lens makes me look like a pro. I am heading down to Chicago for an e30 spring meet up this Saturday with my e30. On the 6-8 hour to-do list that will get me on the road: - shift linkage, evo3 short shifter and Dssr - trans mount with stock e21 bushings - driveshaft     - take e36 CSB off and install new e30 OEM CSB. - install diff - install new OEM drivers door b-pillar latch and make it workable (door currently does not shut). - install new t3 gasket on the turbo. The current one blew out. - DRIVE!!!! .
                                      Took a wire wheel to my drive shaft to clean off the rust and put a coat of rust treatment on it. Flat black rattle can to come tomorrow.
                                      Getting my linkage ready for the Evo3 shifter.
                                      Popped the turbo off.
                                      To fix this
                                      New drivers latch and torx bolts mounted.
                                      Is this my Central Locking Unit that has the internals exposed?
                                      Any idea where this wire/plug goes?
                                      What about this white/red wire? In drivers kick panel.
                                      Thanks for looking!
                                        I have a silly question. Will sanding and painting the driveshaft affect it's balance?
                                          Definitely not silly. I'm taking it to A-1 drive-shadt in Stallis after it gets the final coat of paint. Might as well make sure.
