Ready for the bung.
I had to order new exhaust valves this morning. The retainers were so bad they bent the valves.
Sent from my SCH-I535 using Tapatalk 2
Ready!
nice! I like seeing steady progress!!
That oil pan bung looks super good! I get excited every time I see "Last post by: DrLeadFoot". This build is going to be awesome.
X2
X2
X2.5
Hello, TRM CCV kit for the exhaust and Bimmerworld oil pressure sensor adaptor! I'll run the oil for the turbo and the sensor for the VDO pressure gauge from the adaptor.
Thanks! I'll try to keep this moving. I wanna go fast!
Tape all your receipts to the dashboard for a while as a reminder not to stuff it into a wall
"With great power comes great responsibility" -David Gruber
I won't be able to see the road!
Epic quote! HAHA
Why not just run a catch can off of the valve cover?
Slightly ported and polished up my exhaust ports. Bought a m-coupe diff cover and started prepping some pieces for paint.
I love those diff covers! Keep the progress coming!
Thanks! I'll start the painting soon. I gotta get the tutorial on how to use the bead blaster then the progress will start snowballing.
Is that the cover from Merton? How much did you get it for?
I got it from Merton but loose lips sink ships!
Anyone have an IS lip? Need it for this. My old one broke off at 120.
Been a little tied up with work lately. But I just ordered this: http://www.rallyroad.net/content/e30-steering-column-mounted-gauge-pods
I'll get out to the barn tomorrow for some painting! Well that's the plan at least.
Wrapped most of my hardness and clearly labeled everything.
Also primed my alternator and started media-blasting my m-coupe diff.
I want to pull vacuum for the crank case. More power!
