    StewCrew said:
    That oil pan bung looks super good!  I get excited every time I see "Last post by: DrLeadFoot".  This build is going to be awesome.
    Thanks!  I'll try to keep this moving.  I wanna go fast!
      Tape all your receipts to the dashboard for a while as a reminder not to stuff it into a wall :P
      "With great power comes great responsibility"     -David Gruber
        I won't be able to see the road!
        Epic quote!  HAHA
          Why not just run a catch can off of the valve cover?
            Slightly ported and polished up my exhaust ports. Bought a m-coupe diff cover and started prepping some pieces for paint.
            Sent from my SCH-I535 using Tapatalk 2
              I love those diff covers! Keep the progress coming!
                Is that the cover from Merton? How much did you get it for?
                  Thanks!  I'll start the painting soon.  I gotta get the tutorial on how to use the bead blaster then the progress will start snowballing.
                  I got it from Merton but loose lips sink ships!
                    Anyone have an IS lip? Need it for this. My old one broke off at 120.
                      I knew it was from Merton. I texted him about his and he said he sold it to you:) Good snatch.
                        Been a little tied up with work lately.  But I just ordered this:  http://www.rallyroad.net/content/e30-steering-column-mounted-gauge-pods
                        I'll get out to the barn tomorrow for some painting!  Well that's the plan at least.
                          Wrapped most of my hardness and clearly labeled everything.
                          Also primed my alternator and started media-blasting my m-coupe diff.
                            I want to pull vacuum for the crank case.  More power!
                              More power?
                                I've read and talked to people that if you pull vacuum from the CC you make more power.
                                  A little painting. Still waiting for the Rods and Pistons.
                                  I need to head to the junk yard and pull some wiring harness brackets. Talked to the engine builder and he will take 2 weeks to do the bottom end.
                                  Follow me on instagram for more pics: drleadfoot
                                    Did you disassemble the alternator to paint it, or did you just tape parts off?
                                      I taped it off to paint it.
                                        The bottom end is at the machine shop. pistons and rods should be coming this week. Ordered a MLS gasket in the OEM width.
                                          The crank bolt was a pain.
