pistonse30
    I'm not sure if it was mentioned, but what kind of lip/splitter is that? I really like the look
      I got it off a dude on r3vlimited. $78 if I remember correctly.
        Thanks!
          i am perfectly alright with this thread becoming a pictures-only thread of your car.
          :cool:
            :cool:
            I'll let them do the talking. Haha
            Getting in the garage soon. Update coming.
              I did a practice tap on my old valve cover and it turned out to be pretty easy and not nerve racking. I was nervous about how much metal would be left after the tapping but I think we'll be good!
              I also scuffed up my rain rails to prep them for painting.
              This is what Rat has been up to. Installing a $5000 inverter from a yacht into the barn that he got for free.
                Update:  Tuesday the e30 will go on jack-stands as soon as I get the new passenger caliper and rear brakes on the M3.
                E30 to do list:
                -I think I have sourced a drive-shaft that I will install.
                -My PLX wideband brain just arrived back from warranty work.  Throwing that in.
                -Oil pressure sensor back light and signal wire.
                -CCV
                    -Pull valve cover
                    -Tap
                    -Die grind port for more flow.
                -Change trans fluid
                -Top off diff fluid and RTV seal speed sensor.
                -RTV seal ICV connector and brace hoses underneath intake manifold somehow.
                -Replace Wilwood rotors and front pads.
                -Bleed front brakes.
                -Move BOV to brake booster vacuum.  Going to T into that.
                -Install fuel pressure regulator.
                And that's it!!
                  I got the rack on and scooped up my old exhaust.
                  Go Pack Go!!!
                  • M318M
                    M318M
                    M318
                    That packer flag makes me flacid. I was at that packer viking game in minnesota. :(
                      Heat cracks.
                      Time to port and tap!
                      • Brian.B
                        Brian.B
                        Brian.
                        None of your pictures load
                        instagram @howdoyoudrivethat
                        • 240sxguy2
                          240sxguy2
                          240sxguy
                          Load fine for me.
                          Nice car OP.
                            240sxguy said:
                            Load fine for me.
                            Nice car OP.
                            Thanks!
                            Rotors disassembled. Prepared for painting.
                              Time me.
                                Doing work.
                                • T
                                  T
                                  tsweers89
                                  Did I hear right that you had Kumhoe did your engine? If i would of known that I would have done it for you.
                                    ?? Kummrow put the head/timing belt on.
                                    • T
                                      T
                                      tsweers89
                                       s52 doesnt have a timing belt. haha. No i heard they put the motor together like block, crank, rods, pistons. etc. or did you have the machine shop do all that?
                                        Chain! Haha
                                        I had the machine shop do all that.
                                        • T
                                          T
                                          tsweers89
                                          DrLeadFoot said:
                                          Chain! Haha
                                          Well thats good. But should have done that yourself. Or at least went to somewere good. haha.
