  4. 87 535is - getting started
223 Posts 21 Posters 3.8k Views 2 Watching
  • merlM
    merlM
    merl
    Never weighed it ... Probably a chunk over 3000lbs ... maybe 3200ish ??
    • merlM
      merlM
      merl
      It's OUT !! Head looks good, using some of the parts in the new head.
      • Brian.B
        Brian.B
        Brian.
        Looks good, your head looks about as clean as mine! I have 209K miles though, haha. I take it you sourced a B35 head?
        instagram @howdoyoudrivethat
        • merlM
          merlM
          merl
          Yep ... it is getting port matched now.
          This head has less than 100,000 on it.
          • JeffJ
            JeffJ
            Jeff
            looking good. what is port matching i have never heard of that?
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              It's the long way of saying porting. You smooth out the casting inside to get more flow. You can gasket match so that the ports are as large as the gasket allows, or you can take out more material and just modify the gasket.
              • merlM
                merlM
                merl
                Correct ... Intake will probably take a bit of gasket to enlarge the ports a bit. The exhaust will be gasket matched.
                Newer cars have come a long way and a lot of the joints between the intake manifolds and the head are very close to the same size (matched) but .... back in the day they were not.. so there is one side that is smaller than the other making a ridge ... This ridge between the two is bad.
                Porting = taking material away to create a better/increased flowing port (some of this will be done on my head)
                Port matching = matching the ports or holes in the intake manifold and head as well as exhaust header and head (this is the main thing being done on my head)
                • Brian.B
                  Brian.B
                  Brian.
                  Lookin' good!post up port matching pictures! :)
                  Also, if your E28's close to stock like mine, with no huge stereo or anything crazy. It'll be around 3,200lbs. I just weighed mine last week!
                  • JeffJ
                    JeffJ
                    Jeff
                    ooo ok i haver heard of porting just never port matching.
                    im seconding the porting pictures!
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      im thirding on more pics! this thing is awesome!
                      • merlM
                        merlM
                        merl
                        I will get some posted soon ... Not much to post right now... just painting some small stuff and installing some small stuff. I am NOT going to post all the steps and changes I am making as that would be no fun at all for you guys !!
                        Some stuff you will have to see it in person for  :o
                        • JeffJ
                          JeffJ
                          Jeff
                          i cant see it in person your too far!!!
                          and by the way i could not find the fuel pump i swear i had.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                          • merlM
                            merlM
                            merl
                            I will post a bunch of follow up stuff when it is done Jeff !! ... Couple of pics, nothing major right now. Although over the weekend I did convert the car to vacuum boost brakes but I forgot to take pictures.
                            Block painted and a bunch of wire harness work completed.
                              Looking good=) Did you just tape the head surface off to paint? I'm trying to think of the best way I can do it.
                              • merlM
                                merlM
                                merl
                                Ya taped the surface and the edges all sloppy like ... I wasn't worried about a little overspray. Wire wheeled and dremeled the block and did 2 light coats and 2 heavier coats of paint ... went quicker that I expected.
                                • merlM
                                  merlM
                                  merl
                                  Just got an email that the headers are complete !!
                                  • Brian.B
                                    Brian.B
                                    Brian.
                                    Whod you go through for headers
                                    • merlM
                                      merlM
                                      merl
                                      A group buy a guy did with the manufacturer of the old BavAuto headers
                                      • merlM
                                        merlM
                                        merl
                                        Been a while .. .work is being done but slowly ...
                                        • Brian.B
                                          Brian.B
                                          Brian.
                                          Where'd you get the two collector back pieces from and how much?
