  4. 87 535is - getting started
223 Posts 21 Posters 3.7k Views 2 Watching
  • merlM
    merlM
    merl
    I think it would have made it ... No radiator / AC condensor or aux fan so that gives a bunch of room in the front.
      I had to remove the PS pump and radiator to get my engine out, but that was all.
      Have you ever weighed your car?
        I literally attached my engine hoist to my core support and lifted it right off the subframe/engine combo. Easiest thing I've ever done.
          I can't imagine what your daily routine consists of :shifty:
          • merlM
            merlM
            merl
            Never weighed it ... Probably a chunk over 3000lbs ... maybe 3200ish ??
            • merlM
              merlM
              merl
              It's OUT !! Head looks good, using some of the parts in the new head.
                Looks good, your head looks about as clean as mine! I have 209K miles though, haha. I take it you sourced a B35 head?
                • merlM
                  merlM
                  merl
                  Yep ... it is getting port matched now.
                  This head has less than 100,000 on it.
                  • JeffJ
                    JeffJ
                    Jeff
                    looking good. what is port matching i have never heard of that?
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      It's the long way of saying porting. You smooth out the casting inside to get more flow. You can gasket match so that the ports are as large as the gasket allows, or you can take out more material and just modify the gasket.
                      • merlM
                        merlM
                        merl
                        Correct ... Intake will probably take a bit of gasket to enlarge the ports a bit. The exhaust will be gasket matched.
                        Newer cars have come a long way and a lot of the joints between the intake manifolds and the head are very close to the same size (matched) but .... back in the day they were not.. so there is one side that is smaller than the other making a ridge ... This ridge between the two is bad.
                        Porting = taking material away to create a better/increased flowing port (some of this will be done on my head)
                        Port matching = matching the ports or holes in the intake manifold and head as well as exhaust header and head (this is the main thing being done on my head)
                          Lookin' good!post up port matching pictures! :)
                          Also, if your E28's close to stock like mine, with no huge stereo or anything crazy. It'll be around 3,200lbs. I just weighed mine last week!
                          • JeffJ
                            JeffJ
                            Jeff
                            ooo ok i haver heard of porting just never port matching.
                            im seconding the porting pictures!
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              im thirding on more pics! this thing is awesome!
                              • merlM
                                merlM
                                merl
                                I will get some posted soon ... Not much to post right now... just painting some small stuff and installing some small stuff. I am NOT going to post all the steps and changes I am making as that would be no fun at all for you guys !!
                                Some stuff you will have to see it in person for  :o
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  i cant see it in person your too far!!!
                                  and by the way i could not find the fuel pump i swear i had.
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                  • merlM
                                    merlM
                                    merl
                                    I will post a bunch of follow up stuff when it is done Jeff !! ... Couple of pics, nothing major right now. Although over the weekend I did convert the car to vacuum boost brakes but I forgot to take pictures.
                                    Block painted and a bunch of wire harness work completed.
                                      Looking good=) Did you just tape the head surface off to paint? I'm trying to think of the best way I can do it.
                                      • merlM
                                        merlM
                                        merl
                                        Ya taped the surface and the edges all sloppy like ... I wasn't worried about a little overspray. Wire wheeled and dremeled the block and did 2 light coats and 2 heavier coats of paint ... went quicker that I expected.
                                        • merlM
                                          merlM
                                          merl
                                          Just got an email that the headers are complete !!
