  4. 87 535is - getting started
223 Posts 21 Posters 3.8k Views 2 Watching
  • merlM
    merlM
    merl
    I don't care what anyone says ... getting the transmission out sucks .... a lot !!
    I am going to put it in as one unit ... I will make it work. I am not going to put that transmission on after the motor is in .... Ugghhhhh
      oh definitely not. It was such a breeze to take the engine and trans out in 1 piece and re-install it as 1 piece. You can sit down and do a proper job replacing seals and things when its out of the car too. the next time I need a clutch I will be removing the engine and trans together again.
         Drop the front subframe with motor attached to trans= boom.
        • merlM
          merlM
          merl
          Not enough clearance below the car to pull it off.
            Yeah you need a 2 post lift for dropping the subframe. Can you pull an M30 and trans out in 1 piece? It was tight doing that with an M20.
            • merlM
              merlM
              merl
              I think it would have made it ... No radiator / AC condensor or aux fan so that gives a bunch of room in the front.
                I had to remove the PS pump and radiator to get my engine out, but that was all.
                Have you ever weighed your car?
                  I literally attached my engine hoist to my core support and lifted it right off the subframe/engine combo. Easiest thing I've ever done.
                    I can't imagine what your daily routine consists of :shifty:
                    • merlM
                      merlM
                      merl
                      Never weighed it ... Probably a chunk over 3000lbs ... maybe 3200ish ??
                      • merlM
                        merlM
                        merl
                        It's OUT !! Head looks good, using some of the parts in the new head.
                          Looks good, your head looks about as clean as mine! I have 209K miles though, haha. I take it you sourced a B35 head?
                          • merlM
                            merlM
                            merl
                            Yep ... it is getting port matched now.
                            This head has less than 100,000 on it.
                            • JeffJ
                              JeffJ
                              Jeff
                              looking good. what is port matching i have never heard of that?
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                It's the long way of saying porting. You smooth out the casting inside to get more flow. You can gasket match so that the ports are as large as the gasket allows, or you can take out more material and just modify the gasket.
                                • merlM
                                  merlM
                                  merl
                                  Correct ... Intake will probably take a bit of gasket to enlarge the ports a bit. The exhaust will be gasket matched.
                                  Newer cars have come a long way and a lot of the joints between the intake manifolds and the head are very close to the same size (matched) but .... back in the day they were not.. so there is one side that is smaller than the other making a ridge ... This ridge between the two is bad.
                                  Porting = taking material away to create a better/increased flowing port (some of this will be done on my head)
                                  Port matching = matching the ports or holes in the intake manifold and head as well as exhaust header and head (this is the main thing being done on my head)
                                    Lookin' good!post up port matching pictures! :)
                                    Also, if your E28's close to stock like mine, with no huge stereo or anything crazy. It'll be around 3,200lbs. I just weighed mine last week!
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      ooo ok i haver heard of porting just never port matching.
                                      im seconding the porting pictures!
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        im thirding on more pics! this thing is awesome!
                                        • merlM
                                          merlM
                                          merl
                                          I will get some posted soon ... Not much to post right now... just painting some small stuff and installing some small stuff. I am NOT going to post all the steps and changes I am making as that would be no fun at all for you guys !!
                                          Some stuff you will have to see it in person for  :o
