  4. ‘91 E30
‘91 E30
510 Posts 27 Posters 7.2k Views 4 Watching
    Let us know how getting those top two bolts on the ZF go.
      i have extension jealousy
      did that torque wrench still have enough gusto with that setup?
      Plenty of gusto, was more worried about it blowing apart the universal wobbly joint part of the connection but it went well.
      Thats my favorite tool. M18 fuel high torques. So much nut busting
        Im hoping all the fucking around experience the Miata has beaten into me will translate into some patience with my own car (I have my doubts)
          possible to cut access openings into the trans tunnel for removing the e30 24v transmissions top bolts? I know one day when I have to do the clutch I'd like to avoid engine removal and/or excessive cursing. stripping the interior down would be a cake walk compared to pulling the engine.
            it’ll be alright, just might take some time
              They do similar things for race cars. Have little access panels cut in the body to access things easier. It definitely can be done.
              You could probably cut one in the trans tunnel under the HVAC control panel. Getting a larger piece or replacement material to cover the opening, have some flat head bolts that protrude into the trans tunnel so the carpet sits flat, and put a little bit of gasket between the two surfaces to seal it.
              Or maybe it would need to be closer to the firewall? Is it almost impossible to access them with the ZF? I am praying that I don't have to do this just to get my new slave cylinder in...
                my vote is to just disconnect the top strut mounts and steering shaft, then lower the subframe 2 inches
                  Slave cylinder on the ZF is easy, plenty of room for socket/extension/ratchet
                    My vote is get the socket on the fastener and send it home with the impact
                      the extensions negate the impact effect though so hopefully it transmits enough shock. I had that issue during my manual swap and ended up just pulling the whole engine
                        I am able to get the nuts off of it. But it seems like it's impossible to actually get it out or in without it pinching on the trans or the trans tunnel.
                        Only way I was able to get my broken one out was ripping the dowel out of it and just mashing it out. Maybe I'm taking the wrong approach, but I would be very interested to hear your technique as this is one of my last things to do.
                        My though was disconnecting the trans brace and loosening the motor mounts in hopes of being able to nudge it over just enough to get it in.
                          and remove the skid plate
                          and disconnect heater hoses and drain coolant and remove the entire intake.
                          and the sway bar
                          and probably other things
                          i feel like a lot of stuff under there doesnt have 2 inches of compliance.
                          at that point you might as well pull the motor.
                            did you have a 1400lb/ft impact wrench? the one mitchums has is no fricken joke.
                              I did not have trans bushings in at the time, but did not touch the solid mounts, I removed it with the line still attached. Just kind of maneuvered it out and let it hang
                                OH SHIT, you're that guy from those funny internet videos!
                                  This weekend I got around to doing the detent service on the zf. Thanks to @m42b32 for the trans tools rental.
                                  It’s pretty easy to do, most annoying part was when I had a snap ring fuck-off into a low earth orbit and bounce off the evo/Miata/garage door. Found it after a few minutes luckily.
                                    Mobile is a real dick with putting text where I want without having to go in and edit the post so here’s the difference between the old 5th gear detent and the new 5th gear detent. (New detent on right)
                                      Also they totally revised the pins on the top of the trans and added a coated bushing/sleeve instead of having the detent ride in a machined bore
                                        None of my pins were frozen in the bores, but I figured I’d knock this out while the trans was out. A few definitely showed signs of wear though. Overall pretty easy to do and hoping it wasn’t pointless.
                                          Started pulling the g260, got carried away
