  4. Ummm.... So I took a chance. ***Now with Fire Content***
45 Posts 14 Posters 0 Views 1 Watching
    Glad you're ok. That could have been really ugly to car, garage, and you.
      Congrats on getting it to start up! I'm glad you got the put out quickly with no real damage or injury, that's some scary stuff...
        Caveman - fire good
        man cave - fire bad
        Congrats on the successful revival!
          gives a new meaning to 'it fired right up'
          glad you and the shop are ok!
          • timmerT
            timmerT
            timmer
            SUCCESS!!!
            The old girl is idling on her own!  Still have some adjustments to do... there was a small stone lodged where the mixture screw is, and once I got it out, the screw is too tight for my makeshift extended 3mm Allen wrench to turn.
            I threw some penetrating oil on it to help loosen it up in the meantime while I go purchase a longer wrench.
            The O2 sensor was reading about .72 volts when warmed up. I’m confident once the mixture is leaned out she’ll run like a champ!
            Best part, no fire!!!
            Time for a Busch Latte...
            -Tim
            59BD0CA0-1FF9-4871-83F2-E3648E170001.mp4
            • 59BD0CA0-1FF9-4871-83F2-E3648E170001.mp4
              "It's idling, and it's not on fire". Sometimes it's the little things that make all the difference. 😄 Great job bringing this one back to life!
                Can't wait to see this driving down the road now!
                • timmerT
                  timmerT
                  timmer
                  SHE’S ON THE ROAD AGAIN!!
                  Well, it’s been since 1998, but the old girl is back on the road under her own power.
                  Amazingly, she drives better than I thought!  Goes down the road straight, and most things seem to be working as they should.  It’s easy to tell the suspension bushings, and tie rod ends are cooked.
                  20 miles so far, and looking forward to many more.😁
                  -Tim
                    I really like that color, you made off like a bandit for $250. Looking forward to seeing you get it back into shape!
                      Sounds healthy!
                      Great rescue! What do you think you will do with it?
                      • S
                        S
                        Shannon Marie
                        timmer said:
                        SUCCESS!!!
                        -Tim
                        And now his wife gave him an early birthday present for the garage.....can you guess what it was??......a fire extinguisher!!😂😆🔥🚒
                          Haha!
                          Welcome! Hope to see you guys at the picnic again! Thanks for supporting Tim’s addiction.
                          -Brian (who had the black E30)
                            Sounds great! Besides the dash cracks, it looks like new on the inside too. Great to see this driving again.
                            • timmerT
                              timmerT
                              timmer
                              Sounds healthy!
                              Thanks Brian!
                              I’m gonna take my time with this one, try to do most the work myself, and keep it as original as possible.
                              I’ll probably start working on the interior next, freshen up the suspension, and tackle the little things for now.  I’ll start saving my pennies since I dumped my savings into the S52 swap for the ‘86, lol.
                              • timmerT
                                timmerT
                                timmer
                                Not much new to update on the e21 project... put several hundred miles on her over the summer with no issues while I focused on other projects.
                                Interior bits & pieces are on the agenda while the cars are sleeping for the winter.
                                Scored a decent set of tan e30 sport seats since I can’t find any e21 replacements. I’ve heard they fit nice, but will need work to fit the uneven floor of the old girl. I’d appreciate any insight from any local experts!
                                Here’s to a good winter, looking forward to the next driving season!  Keep ‘er outta the ditch!!
                                -Tim
                                  Those are some of the cleanest original seats i’ve seen this side of BaT!
                                    The approach I took was cutting out the old seat perch risers from the e21 and welding in cross bars that sit a lot lower. The problem with using the e21 seat perches is the e30 seats will sit way too high. Making new cross supports lower in the chassis is the only way to go.
                                    • timmerT
                                      timmerT
                                      timmer
                                      Thanks for the info!  I’ll tear into it and see what I can come up with...
                                      I was pretty stoked to find these seats locally. There is a bit of wear on the side bolsters, but nothing I can’t fix up.
                                      • timmerT
                                        timmerT
                                        timmer
                                        Took a staycation since both of our trips to Canada had to be cancelled.... had some time to rip out the interior, installed new carpet and the seats.  Had to fab up some brackets to account for the uneven floor of the E21.
                                         Not perfect, but much better!   Lots of work left to do...
                                        -Tim
                                          Mad jealous of your lot, house, and shop building.
                                          G O A L S
