  4. Ummm.... So I took a chance. ***Now with Fire Content***
e21
45 Posts 14 Posters 859 Views 1 Watching
    Sounds healthy!
    Great rescue! What do you think you will do with it?
    • S
      S
      Shannon Marie
      timmer said:
      SUCCESS!!!
      The old girl is idling on her own!  Still have some adjustments to do... there was a small stone lodged where the mixture screw is, and once I got it out, the screw is too tight for my makeshift extended 3mm Allen wrench to turn.
      I threw some penetrating oil on it to help loosen it up in the meantime while I go purchase a longer wrench.
      The O2 sensor was reading about .72 volts when warmed up. I’m confident once the mixture is leaned out she’ll run like a champ!
      Best part, no fire!!!
      Time for a Busch Latte...
      -Tim
      59BD0CA0-1FF9-4871-83F2-E3648E170001.mp4
      And now his wife gave him an early birthday present for the garage.....can you guess what it was??......a fire extinguisher!!😂😆🔥🚒
        Haha!
        Welcome! Hope to see you guys at the picnic again! Thanks for supporting Tim’s addiction.
        -Brian (who had the black E30)
          Sounds great! Besides the dash cracks, it looks like new on the inside too. Great to see this driving again.
          • timmerT
            timmerT
            timmer
            Sounds healthy!
            Thanks Brian!
            I’m gonna take my time with this one, try to do most the work myself, and keep it as original as possible.
            I’ll probably start working on the interior next, freshen up the suspension, and tackle the little things for now.  I’ll start saving my pennies since I dumped my savings into the S52 swap for the ‘86, lol.
            • timmerT
              timmerT
              timmer
              Not much new to update on the e21 project... put several hundred miles on her over the summer with no issues while I focused on other projects.
              Interior bits & pieces are on the agenda while the cars are sleeping for the winter.
              Scored a decent set of tan e30 sport seats since I can’t find any e21 replacements. I’ve heard they fit nice, but will need work to fit the uneven floor of the old girl. I’d appreciate any insight from any local experts!
              Here’s to a good winter, looking forward to the next driving season!  Keep ‘er outta the ditch!!
              -Tim
                Those are some of the cleanest original seats i’ve seen this side of BaT!
                  The approach I took was cutting out the old seat perch risers from the e21 and welding in cross bars that sit a lot lower. The problem with using the e21 seat perches is the e30 seats will sit way too high. Making new cross supports lower in the chassis is the only way to go.
                  • timmerT
                    timmerT
                    timmer
                    Thanks for the info!  I’ll tear into it and see what I can come up with...
                    I was pretty stoked to find these seats locally. There is a bit of wear on the side bolsters, but nothing I can’t fix up.
                    • timmerT
                      timmerT
                      timmer
                      Took a staycation since both of our trips to Canada had to be cancelled.... had some time to rip out the interior, installed new carpet and the seats.  Had to fab up some brackets to account for the uneven floor of the E21.
                       Not perfect, but much better!   Lots of work left to do...
                      -Tim
                        Mad jealous of your lot, house, and shop building.
                        G O A L S
                          How is the height of the seats? I put e30 sport seats in my previous e21 and they sat too high. I had to cut out both stock seat mounts and weld in two new ones that ran from rocker to trans tunnel to make the seat height where I wanted it.
                            man those floor pans are clean! Interior looks great.
                            • timmerT
                              timmerT
                              timmer
                              I’d say they’re still an inch or two too high, but it works for me... I wouldn’t want to be much taller or bigger since the steering wheel isn’t adjustable. Comparing it with my E30, there isn’t too much difference.
                               Way more comfortable than the original seats though!
