chit chat thread
Wow, that's a load!!! 17,000 extra???
Are the seams tight enough on the smooth to keep fluid spills from getting underneath the tiles?
Did you get a killer wholesale bulk price on these? Common pricing online is around $3/ft2.
IDK about the fluids yet. I have yet to lay them out, but they snap very tightly together.
I got a deal because the guy didn't want to sell sections, so I had to buy all of it.
Damn, I epoxied my floor last year. Otherwise I would have been interested.
Might want to watch this. He's a little annoying, but good info...
Same guy?
I agree though. Its good info.
This is the stuff that I think I have:
SnapSports ReActive
suspended modular flooring –Solid top design shall be 9.8425" x 9.8425" x 3/4" (250mm x 250mm x 19mm)
high impact PP (polypropylene)
each tile has 841 individual support legs. Weight: 10.75 oz. (304.79g)
PRODUCT TEST RESULTS
• Flame Spread Index (ASTM E 84): 90
• Smoke Generation (ASTM E 84): 90
• Friction (ASTM C 1028): Dry – 0.74, Wet – 0.53
• Compression vs. Crush (ASTM D 3998): No Break
• Noise Reduction Coefficient (ASTM C 423): 5 - 10%
• Rolling Load (DIN 18032-02): Pass • Force Reduction (ASTM F2772): Class 1
• Standard Deformation (DIN 18032-02): 0.9mm • Ball Rebound (DIN 18032-02): 98%
• Load Bearing Capacity (DIN 18032-02): >200 psi • R-Value: x<1
• Flatness: 0.0mm • Lateral Movement: 0.00" – 0.035"
SANITARY INFORMATION
• Fungus Resistance (ASTM G 21): No Growth
• Resistant to the following: – Bacteria and Mildew – Staphylococcus – Klebseilla Pnuemoniae – Pink Staining Organism – STV Reticulum
• Tested and Certified by the NSF (National Sanitation Foundation)
HOW MUCH I HAVE:
190'x100'
19,000 square feet
27360 tiles
294120 oz of tile
or
18,382.5lbs of tile
Its technically a gym floor application, but unless you park your steam roller in your garage everynight, it should work perfect for a workbench or a car. I plan on installing most of it this weekend.
I tried to capture the color. Its a very light blue, almost grey. I have a basic harbor freight 5mil glove on, one has my concrete floor behind it, the other my white truck.
Let us know how it goes after install!
Just an FYI your signature links don't work.
Will do!
Also this^
Also this^
Fixed - thanks for letting me know
I need an intervention. I bought another Sienna van which brings the total to 3. It was my parents van and my mom hit a deer and insurance totaled it. I bought it back for $2000. It needs a hood, bumper cover, both headlights, radiator, condenser, fan shroud, grill, and part of the radiator support replaced. Insurance quote was 6700. I ordered everything but the core support for less than 1000 shipped from RockAuto. And I have a core support to pick up at a local salvage yard for 100 tomorrow. I would have preferred used parts already the right color but I couldn't find any remotely nearby so i will be trying my hand at painting. It's a facelift 2nd gen which I guess not many are in junkyards yet. It's an '09 XLE with 120k miles. I will not be engine swapping this one though. It should replace the '01 with 210k on it. Insurance valued it at about 9k.
Anyone need a deluxe green 1st gen Sienna XLE, it even has a VHS player? It has a little rust but runs good, new genuine VVT solenoids, new A/F sensors, all 4 shocks/struts just replaced. I'm thinking $2500ish
should be several factors greater than needed for a car.
probably not going to support the point load of a floor jack castor, but i think that is the case for any type of plastic modular flooring.
did you get any ramp edge pieces?
I had a 1st gen Sienna, I actually liked it more than my current 2nd gen. It felt like a Toyota product, this feels like a Nissan product (now my infiniti is going to spitefully break). I know where the VVT solenoids are on the 1MZ, do you have any idea where they are on the 3MZ? I have what I believe is some VVT rattle and wanted to check/clean the filters if I can find them but so far I have not been able to.
I don't have any edge pieces unfortunately.
I will test a large section before I do the entire floor. If it doesn't work for me I will just sell it all. But I think for the most part even if it cant sustain using a floor jack, it will be perfect for work benches and such. I will post more as I install it this weekend.
You should finish one of your other projects. Like the E36 or the m5x sienna.
Have fun with your 6-8 inches Milwaukee noobs
I will look at the 3MZ I have from the '04 and see where they are, I would think it wouldn't be that different? But its dual VVTi instead of just the intake cams I think so the heads must be different.
I will say the 1st gen seems sturdier but the face lift 2nd gen that I am repairing has the 2GR-FE which is way more powerful and the 5 speed is nice. It tows so much better than the 1MZ and 4 spd transmission.
Yea, 4 weeks of work left and then I am off for the summer so the m50 Sienna will get worked on then. I'm planning to drive it to The Hawk vintage races in July.
