Non-BMW Stuff on a BMW Forum
    what size were those stickers?
    I'm assuming you mean the wheel stickers and not the people? Lol
      you got it! thanks.
        gilber33 said:
        Because of the glue used for the tint?
        Any tips or tricks you can recommend? I was gonna go at it with a heat gun and just start peeling.
        Steam. Use a steamer, not a heat gun and save yourself a ton of time. You can get them as cheap as $10, although a bigger one might be a better idea. the one I used was $30 and has a cloth pad which made it perfect for window tint removal. Similar to this:
        Image result for steam cleaner
          This!
          I had some pretty awful tint on my old M3 (turning purple, way too dark, bubbling all over the rear window). I used a handheld garment steamer since that was what was available, a larger device would definitely be recommended. Left over glue can be removed with ammonia, though make sure to do it in a VERY well ventilated area or you will end up feeling like garbage. I definitely don't want to do that job ever again...
            sounds like having a tinting company remove it may be worth it.....
              There is a mobile tint guy in the cedarburg area that did one of my old cars, and he'd remove the tint for about $120. Definitely worth it.
              In the meantime, exhaust back in including new eBay cat back.
              Got a subwoofer for the trunk to fill in some bass from the old speakers.
              Got the head off the donor engine and really happy with how the cylinder walls looked.
                pretty awesome considering that piston may have slid along that bore roughly 30 billion times.
                  I agree. Much better than I was expecting. Will move forward with rebuilding it now.
                    My quick estimation is around maybe 500 million reciprocations per 100,000 miles driven. You're either bad at math or using hyperbole.
                      bad at maths. that's why i said 'roughly' 😂
                        What eBay “brand” did you go with for the exhaust?
                          This one:
                          Fitment was actually pretty good. I haven't clamped the two sections together yet and I'm a little skeptical if the provided clamps are big enough, but we'll see tonight.
                            gilber33 said:
                            This one:
                            Curious to see how it sounds, let us know.
                              I will!
                              Question time: I ordered a keyless entry box and I'm trying to figure out what wiring diagram I should use. I have read the write-ups for the REC-43 keyless entry and that one is very simple with a power, ground, and an opening and closing sign wire that is spliced into the harness in the trunk. I found one on amazon for a bit cheaper with great reviews but it has more options than the REC-43, thus a more complicated wire harness. Here's the wiring options for it. There's different options for how your car is equipped; this is only showing the section of harness related to the lock/unlock signal. There is a separate 12v and ground for the box.
                              I think I'm going to start with splicing the white (closing signal) and white/black (opening signal) into the correct wires in the car harness, unless someone reads this differently than I do.
                                gilber33 said:
                                I will!
                                you've read it right.
                                white - closing signal wire
                                white/black - opening signal wire
                                yellow + yellow/black - connect both to ground (e30 is "negative pole" grounded)
                                i used the signal wires found in the harness right under the truck lock. i ran the unit's constant 12v positive back along the drivers side to the antenna harness and i ran the ground to the battery. sorry, my wiring is messy - i connected the whole unit with quick-connects in case it fails in the future i can just swap it out quickly instead of cutting out splices. . you can actually see my unit has the same colors as yours. red = 12v constant, yellow/black = ground, solid white = closing, white/black = opening
                                  Thank you so much! That is a ton of help. I was going to use everything you described, so the confirmation is great.
                                    I also did the same thing to double confirm on both my E24 and E30.
                                      Thanks for your help on the keyless entry. Made install so much easier and it worked! Super gratifying to have something as simple as remote locks.
                                      On to another thing. Anyone install a performance chip in their e30? Obviously they add some power, but is it significant enough to make it worth it? Looking for some honest feedback on them.
                                        Re chips: Mark D (D'silva) and SSSquid have good reps of late. Both have multiple options based on octane and injector size
                                        http://www3.sympatico.ca/mdsylva/
                                        https://www.sssquid.com/v3/
                                        Earlier the options were mainly the Conforti (JC) now sold by Turner and Dinan both of which needed higher octane but used the stock injectors. The rep on the Conforti was some impact along the entire rev range while Dinan was just at top end. Both bump the red line up. I've got an old Conforti on the track car. Used it when it when the 325i was just a DE car and started using it again last year since it was class legal. I can feel it in the midrange on corner exit which is where I wanted a little help.
                                        When megasquirt came out the focus on chips decreased but the SSSquid tunes have lead to new interest.
                                        Is it "worth it"? You've got an e30, short of FI or an engine swap the car is pretty much a low HP brick. A chip will tweak it a little bit but you'll still get dusted by minivans.
                                          Its both a slippery slope and an all-or-nothing endeavor.
                                          If you get a cam then you need a cam gear to keep timing dialed in. Then you should really get stiffer valve springs that support higher revs. If you get a big enough cam you should get some headwork done. If you get headwork done you would be smart to get megasquirt or some sort of way to keep the fuel mixtures safe and optimized, etc etc.
                                          If the steering, shifter, and throttle response are sharp it should be, maybe added some sway bars, some bracing and removed weight within reason, then the overall feel of the car should suffice.
                                          At the end of my turbo m20 and cammed/modded M52 escapades I would have happily gone back to an M20 with a 2.8, ITBs, megasquirt and a mild cam upgrade. Something that might only dyno 185whp but would be crisp, responsive, plenty of top end pull, and easy to work on
