Non-BMW Stuff on a BMW Forum
    But the results are WELL WORTH IT!
    Yes, in the end it was worth it. Also got new headlight covers to help clean up the front of the engine.
      Getting the engine almost all put togrther. Accidentally tossed out the radiator rubber mounts with the old radiator so waiting for new ones of those to finish that up.
        The old dirty delphin is looking good!  Can't wait to own it again after you get bored.
          Lol. Well, lots of credit to you for so much of the powder coating in there.
            Looks very nice indeed. Getting close!
              Other than the exhaust a few small things in the engine, the big stuff is all done. Last few to do's are remote door lock thing install, new head unit that blends in better than the cheap one I got last year, would like to attempt to peel the tint off.
              Got some bmw center stickers
              And finally put my family stick people on it. Lol. Came free in a Road and Track magazine.
              • The Full BananaT
                The Full BananaT
                The Full Banana
                At first, I thought your stickers depicted two wives of varying sizes.
                Engine bay is looking fantastic!
                  I've always had a thing for wives that were my exact height and wives who are just a hair shorter. Couldn't make up my mind so I got one of each.
                    Make sure you are well ventilated removing that tint. I got super sick last year removing old tint.
                      Because of the glue used for the tint?
                      Any tips or tricks you can recommend? I was gonna go at it with a heat gun and just start peeling.
                        what size were those stickers?
                          I'm assuming you mean the wheel stickers and not the people? Lol
                            you got it! thanks.
                              Steam. Use a steamer, not a heat gun and save yourself a ton of time. You can get them as cheap as $10, although a bigger one might be a better idea. the one I used was $30 and has a cloth pad which made it perfect for window tint removal. Similar to this:
                              Image result for steam cleaner
                                This!
                                I had some pretty awful tint on my old M3 (turning purple, way too dark, bubbling all over the rear window). I used a handheld garment steamer since that was what was available, a larger device would definitely be recommended. Left over glue can be removed with ammonia, though make sure to do it in a VERY well ventilated area or you will end up feeling like garbage. I definitely don't want to do that job ever again...
                                  sounds like having a tinting company remove it may be worth it.....
                                    There is a mobile tint guy in the cedarburg area that did one of my old cars, and he'd remove the tint for about $120. Definitely worth it.
                                    In the meantime, exhaust back in including new eBay cat back.
                                    Got a subwoofer for the trunk to fill in some bass from the old speakers.
                                    Got the head off the donor engine and really happy with how the cylinder walls looked.
                                      pretty awesome considering that piston may have slid along that bore roughly 30 billion times.
                                        I agree. Much better than I was expecting. Will move forward with rebuilding it now.
                                          My quick estimation is around maybe 500 million reciprocations per 100,000 miles driven. You're either bad at math or using hyperbole.
