  4. chit chat thread
chit chat thread
  • N
    N
    Nick_F
    I used Delphi on my n54 in desperation and had issues and immediately went back to Bosch.  The Bosch cp's have a lifetime warranty as of 2017-ish so no reason to buy anything else as far as i'm concerned.
    Yea I've seen that more than once now. Went with bosch's
      For clarity, I have nothing against Delphi in general but in this application I would not recommend them.
      • N
        N
        Nick_F
        When the weather gets a little nicer I'll get to the coils. Today got a little bored while healing and the gf helped me do an update I've been waiting to do
          You opened the vent... bold move!
            No Piano black?
              Drivers side external door handle just broke. I don't know why e36s even came with door cards. At a minimum they should have come with some kind of quick-release fasteners... Maybe I'll get some hood pins to put it back on with this time.
                I just leave my door cards in the garage.  The door handle is a pain, have you done one before?
                  No. I see they're kind of expensive as well, so I'm hoping I don't have to replace the whole thing...
                    my drivers front brake caliper partially locked up on the way home from work friday night.
                    i felt it happen about 4 blocks from home and pulled over to confirm. i finished my drive home.
                    smoke was pouring from the wheel well when i got there.
                    i was impressed by the heat generated.
                    i busted out the lasers and glow sticks and had a rave so i wouldn't waste the smoke show.
                    taking the bus to work while waiting for parts is not fun.
                    • ChrisOC
                      ChrisOC
                      ChrisO
                      I have no idea what thread or what member this was in but like 6 months ago someone posted that they found a non-running e34 m5 in Minneapolis. It was in a garage and looked like it had body damage.
                      Any info on that or why nobody here bought it?
                        I think @Jdesign was interested. I think it had a blown motor.
                        • ChrisOC
                          ChrisOC
                          ChrisO
                          Thats alright, it's somewhere in a dark garage weeping for a cast iron 5.3 😢
                          jk
                          Pretty sure a s38 rebuild costs like $8000, but every other e30 m3 I see has a s50/52 in it. I'd enjoy something like that instead of it rotting in a garage.
                          The blown motor and trans is probably worth a few grand aswell
                            Luckily they're super easy to change in compacts/sedans versus coupes/verts. You have to remove the window and rear window guide and you'll have all the room you could need. Removing and reattaching the linkage to the door latch is worst part about it. If you pull the handle and it either gets hung up or doesn't pop the door at all, your handle snapped and needs to be fully replaced. The other thing that sucks is that they did not use the same style for handles throughout e36 production. I've encountered three different ones so you will want to remove yours to at least see exactly what you have before going and searching for a replacement. There are plenty of part outs for a used one to be had=)
                              That was me. I never went to go look at it. It did have body damage and rust, I got additional photos as requested, and the motor was not blown, but I was told it just didnt run. The owner had no time or idea on what it would take to fix it and unfortunately he responded late to me and I bought something else. A lack of details made me skeptical about a 6 hour drive one way. It did have the rare M-Technic mirrors and some interesting parts that would make it worth buying for just those, but I passed up on the deal. I have his email still if you want to contact him, PM me.
                                Good to know, I replaced mine on my coupe.  There are some key tricks to avoid breaking parts.  Like removing the plug on the back edge of the door and reaching in with a screwdriver to push the outside trim retaining plate forward and it just comes off.  Some youtube DIY videos just pull on it until it breaks...  Mark where the bolts are for the window track before loosening.  It was tricky to get it aligned properly.  Although I was trying to get it adjust so that I can close the door without the window hitting the top because my window drop doesn't work.
                                  That might be a coupe thing too. Since the compact has framed windows I've never had an issue removing the guide and reinstalling without marking anything.
                                  That is one big thing people do not seem to know when they do the handles. That's soley what that hole in the door is for haha
                                    I managed to get mine out yesterday. I didn't have to remove the window track because there wasn't one, so I've got that going for me.
                                    The handle assembly was broken in multiple places. Started half-assing it back together. Hopefully it will last long enough for me to find a replacement. Current door opening procedure is:
                                    1. Forget that it's broken
                                    2. Try to open door
                                    3. Get pissed. Give door handle the bird as I walk around car.
                                    4. Open passenger door and reach across the car to grab the inside handle.
                                    5. Walk back around car, grab handle, and realize door is only half open.
                                    6. Repeat steps 3 and 4.
                                    7. Walk back around car and get in.
                                      #12 was not inside of your door blocking the way?
                                      http://www.realoem.com/bmw/enUS/showparts?id=CG53-USA-06-1995-E36-BMW-318ti&diagId=51_2055
                                      If not I'm thoroughly surprised your window doesn't rattle around in your door when down and that it goes up and down straight. I've had the rubber "guide" fall out of mine before and it caused my clips to snap and the window to fall
                                        2. Try to open door
                                        Don't worry, you get used to it.  Mine was broken for over 6 months.  I almost forgot to use the working handle after it was fixed.
                                          Correct, it's missing. The window does rattle when down, I just never realized what the issue was. Currently don't even have the ambition to work on my project car, so working on the daily is a real chore. I will get it all fixed up properly at some point though...
