Joined the Club Today
All the brackets are rusted for sure. I just ran the new brake line along the old one as I had intended to redo that all at some point. I don’t remover if the fuel hoses were replaced at the filter or not.
Yeah I saw that when I was under the car. Is there enough room on the top of thank to replace the soft lines from the tank to the hard lines? I’m having a hard time visualizing it right now, the tank doesn’t have to be dropped does it?
If it were still warm out, I probably would just order a whole new tank as the Spectra one is well documented as being pretty much an OEM replacement. It’s also only $170 compared to $1200 for the OEM one.
replace it, you'll tank yourself later.
I’d replace the tank while you’re in there, it leaked over half. The fuel pump is new so then you’d have a fully refreshed fuel system.
*bum dum tiss*
Probably the best idea. I’ll start doing some research, but for some preliminary readings, how much of a pain in the ass is it? From some of my browsing, doesn’t look too terrible.
The hardware screws into studs that are welded into the chassis, so unless you manage to get the screw remnants out you won't be able to get the new stuff in.
Replace the soft lines if you're replacing the hard lines. Parts store hoses work just fine.
Make sure to get high pressure hose for the feed side (~$8/ft) vs the low pressure stuff at a buck or two a foot.
At minimum replace the hoses by the fuel filter. The hoses up by the motor seemed okay.I found that the parts store hose I bought to connect to the fuel filter fit poorly and kinked, so maybe think about getting the one 180 degree curved hose from FCP or something. Others experience may vary, but that’s my two cents.
+1 on replacing it.
Its really not that bad. Biggest challenge is getting those rusted nuts and bolts out that hold it in place. Once they are out your pretty much home free.
+1 on replacing it.
Good to know. I'll probably get an estimate of it when I do the clutch line.
After some debating, I think I'll probably wait to do the tank until spring. I bought a propane heater for the garage, but I think this job would be best done when it's not below 20 degrees out. I do plan to get the new booster in, bleed the brakes, and replace the rubber clutch line with the braided SS one I bought.
This might change when I can get under the car and get a better estimate of what the entire job will entail and what other tubing I will need to replace.
Also want to give my parents one of their stalls back.
I recommend OEM fuel line, the stuff FCP sells (CRP) is good. It is much more flexible than parts store line that I have previously used. I had replaced fuel lines with parts store high pressure hose and it leaked after a year when it was really cold out. The OEM has much better flexibility and I've never had a problem with it. Buy 5 meters of 8x13 from FCP and send it.
32$ for 5m is only 2$ a foot. It's totally worth it to have a roll on hand.
https://www.fcpeuro.com/products/bmw-fuel-line-13311722262-5m#desc
Replaced the booster last night, picked one up from @m42b32. Used @snaprecommendation and pumped the master cylinder piston by hand a little bit to push some fluid through before attaching to the booster. Soft fuel lines are little long so I was able to detach the manifold but keep everything attached otherwise, just enough room to sneak the old booster out and the new one in.
Didn’t bleed the brakes because I wanted to wait until I replaced the clutch line to do so. Replaced the rubber clutch line with the condor speed shop braided stainless steel one. Never bled a clutch before, but I’m assuming it’s similar to the brakes with opening the bleeder valve on the slave and pumping the clutch pedal to push fluid through? Does it matter if this is done before or after the brakes?
It's leaking coolant and power steering fluid. Neon green and red droplets on the oil pan. Knew about the coolant as when I had started it a couple times, there was a puddle up front. Haven't been able to figure out where it's coming from as the top looks dry, figure it coming from the coolant pipe somewhere. Power steering looks like it might be from the lower banjo bolt.
Issues for another time, trying to be in the garage as little as possible with how cold its going to start getting.
Not horribly surprised to hear the coolant pipe started leaking. The opening in the timing cover for that was a bit corroded, and with it being cold leaks seem unsurprising. I put 2 new OEM o-rings on that to attempt a seal.
There may be residual power steering fluid on the top of the pan, it leaked quite a lot before I realized what was happening with the lines. I'd hold off on judgement on that one for a bit. I put new crush washers on the upper line, but I didn't take the lower line off due to it being attached already.
i've bled a few clutch slaves and/or clutch masters in my day. ive never bench bled anything, and I've never had a problem. you will need a helper though, and your process is correct. i did have one that seemed a bit soft after initial bleeding, so i used the gravity bleed method - i.e., top off the reservoir, crack the bleeder open and walk away, periodically checking it. the 2nd bleed attempt worked fine then.
Recommendation for correcting? Some sort of larger fitting on the end?
I have had much luck with clutch system bleeding with patience, once you get it together and fluid in, pump the pedal by hand a few times every half hour when you walk by. If you watch bubbles will rise into the reservoir. Every time you pump it the bubbles make their way higher in the system. Do no press the pedal with the slave removed from the transmission though, disappointing results.
It sounds stupid but I have done several different car this way. Except my Volvo, that requires pressure flushing it backwards or you will never get all of the air out.
Was having nightmares that my scene points were too low, so I bought a couple E U R O items to mend that.
Got these at both a pretty good price.
I picked up one of those wiring adapters for 6 button OBC to euro clock to make life easier for my self. Clock gets power as the light for it comes on, but when I use the set buttons on the front of the clock, the hands don't turn. I don't think I am doing anything wrong as this is pretty straight forward process, but I was under the impression I was buying a working unit. I have messaged the seller already.
Are these repairable like the speedometers are?
I wired mine in using a 6 button OBC harness that I modified. I remeber it being straight forward without issues. I assume its repairable as there are guys that rebuild them like E3DAD.
can you post a picture of the connection?
