  3. Parts Wanted
  4. WTB E36 axles
WTB E36 axles
13 Posts 4 Posters 130 Views 1 Watching
    Whats your price?
    Just message me, we can figure something out.
      M axles need M wheel hubs, you probably know that though.
        Honestly I didn't know that. Here's the other problem, I have no idea whats in/on the car because its a bastard of parts. Any obvious clues to know the difference?
        All I found online is this: 328 takes a 30mm nut and the M takes a 36mm nut
          The M axles have a thicker shaft, it is quite obvious just looking under the car if you know what to look for.  The non M axles are straight and about 1" diameter.  The M axles get thicker right after the boots on both ends and are more like 1.25" diameter.  The hub difference is because the splines into the hub are larger or more of them on the M axles.  I THINK the bearings are the same.
            Im guessing I need non-M/// Axles judging by this picture?
              Yes that is a non M axle.
                I have an entire m3 rear subframe, brakes, etc to go with the axles that I have.
                  Good deal. I will PM you.
                  • SamHolzmannS
                    SamHolzmannS
                    SamHolzmann
                    I have m axles and trailing arms. Shoot me a fb message if you still need some
                      TJ has the goods, but if that doesnt work out, I will shoot you a message Sam!
